Engine going past redline.
Old 28 Oct 2003, 04:31 pm
Default Engine going past redline.
[:I]I got an auto 04 Turbo H.O. I was playing with a stang GT and stomped her, going about 35mph and the red went 1k past redline[xx(]
Is there a problem?
Old 28 Oct 2003, 05:18 pm
cool, don't do it to often o.k., did you win?
punch
Old 28 Oct 2003, 06:15 pm
Since installing stage1 the autostick WOT shifts normally are around 62k-63k. The engine can handle that gracefully without any issues.....
Old 28 Oct 2003, 06:40 pm
punch
Yep, it was an older GT.[8)]
http://www.cardomain.com/memberpage/473529
Old 28 Oct 2003, 09:08 pm
Is there a problem?
Are we talking 1k as in 1000 RPM past red line? Or 1k = 100 RPM past red line. If it is 1000 RPM past red line (7000 RPM), you have a problem as the rev limiter should have cut you off. If it is only 6100 RPM, then you are fine.
I wish that my autostick would rev past 6000 RPM. In Drive it shifts at 5700 RPM and about the same in autostick. Can't wait for Stage 1 and 6300 RPM!!!
Marc
2003 PT Cruiser GT Turbo, Silver
1985 Dodge Omni GLH Turbo 16V, Black
http://connect.to/YBT
Old 28 Oct 2003, 10:36 pm
Send a message via AIM to sakigt
When I haul a** my normal automatic does the same thing. Goes higher than when I have it in autostick. Probably not harmful but as far as engine efficiency goes, you are probably past your peak hp at the normal shifting point.
14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!!
Old 29 Oct 2003, 12:02 am
Is there a problem?
Afraid it was the big 1K[xx(]
Old 30 Oct 2003, 08:13 pm
Well, factory tachs are not the most accurate either, but I don't think it would be a big K off.
Old 31 Oct 2003, 03:21 am
I rode in friends V-8 5.0 GT Mustang the other day. There is no way in he!! that my GT can keep up with his V-8. That car is downright scarey when you romp on it. He's going to let me drive next time. I'll post after the ride.
Old 03 Nov 2003, 12:52 pm
"Yep, it was an older GT"[^]
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Review: $2200 for a NA replacement engine PT Ctown General PT Cruiser Discussions 8 24 Jul 2006 01:08 pm
Engine problem BORICUA Tech & Performance Forum 49 03 Apr 2006 05:15 am
Complete Engine Swap TaylorMade General Turbo Discussions 35 05 Jan 2005 03:34 pm
And you though your GT'z engine got busy RODRUN General Turbo Discussions 14 14 Jan 2004 09:49 pm
