Error Code 320
Old 17 May 2010, 12:18 pm
Default Error Code 320
I have a 2001 PT. Driving down the road the car just dies. After coasting to a stop you can turn the car off wait a couple of minutes and the car will start and run for awhile longer. I checked the codes and am getting a P1684 then a P0320... Will changing the canshaft sensor fix this?
OK Just to be sure I disconnected the wiring to the camshaft sensor and checked for bad spots, found none.. Also I removed the neg battery post and cleared the computer codes. Took it back out for a drive and it again died four times. Checked the codes only revieled a P1684. When it dies trying to start it is no good. You must turn the key off wait at lease two minutes then it will start again.
Old 17 May 2010, 12:42 pm
Default Re: Error Code 320
Welcome.
Probably camshaft sensor - be sure and buy a Chrysler part - others have had aftermarket sensors die quickly or not work.Also check the wiring - you might have a place wher insulation got eaten off.
What does the error code PO 138 really mean? TheFox General Turbo Discussions 8 15 Jul 2012 10:10 pm
Error Code bds02pt Tech & Performance Forum 2 29 Jan 2010 03:01 pm
Error Code saldagus Tech & Performance Forum 2 25 Nov 2008 09:51 pm
CPS Error Code smokeydan1 Tech & Performance Forum 16 23 Sep 2008 09:58 pm
Error code??? russ00001 Tech & Performance Forum 0 29 May 2007 04:24 pm
