PT GT Brake Caliper Question
Old 27 May 2010, 09:00 pm
Default PT GT Brake Caliper Question
Hi I am new to the PT Cruser World. I am replacing the front brake calipers on my 2005 GT. The 2 I bought from my local parts store look exactly the same, Except one is stamped TURBO as it should, But the other does not. I am not sure if it is the correct one or not. As I stated before, They do look exactly the same. Any help on this would be great.
Old 28 May 2010, 12:39 pm
Default Re: PT GT Brake Caliper Question
Welcome to the forums.
The calipers are the same - EXCEPT - the GT calipers have a wider opening to fit the fatter disc on GTs.
Measure the side-to-side opening.
As you noted, the GT calipers have turbo on them.
Old 28 May 2010, 07:21 pm
Hey thanks for the quick answer!!! I returned it today for the correct one, They had put the wrong one in the box as it turns out....
Old 29 May 2010, 06:59 am
Quicksilverdon, I keep seeing Turbo-Lite, What exactly does that mean?
Old 29 May 2010, 07:11 am
Turbo-Lite is what Chrysler came out with in about 2004-2005. It's between the full turbo an the non-turbo. Same basic engine block and turbo as the GT but de-tuned to only put out 180hp on regular gas, no premium necessary. It can be brought up to full GT specs with a Stage 1 computer and larger injectors in the 2004 models. The larger injectors were put in all turbo models beginning 2005 (I believe, I might be off by a year).
Old 29 May 2010, 10:11 am
Crewzin pretty well covered it.
the turbo came out in 2003 - the GT.
In 2004, they added another model - "turbo lite" - exact same engine as the GT, but computer controlled for lower boost, and runs on regular, and puts out 180 HP.
I ordered 4-wheel disk ABS, so I have same brakes as a GT as well, but not all turbo lites do.
What Brake Caliper Color? amazingarthur Exterior Accessories Forum 21 29 Jul 2004 11:20 pm
Brake Drum and Caliper Paint technobear Exterior Accessories Forum 6 05 Jul 2004 10:01 pm
A brake question Alan Welch Wheels, Tires, Suspension 4 09 Feb 2004 06:38 pm
Red G2 Brake Caliper Paint Set 4 Sale! yobiebs Vendors & Buyers Forum 2 03 Nov 2003 05:18 pm
Brake Caliper Paint? PTRON General PT Cruiser Discussions 3 17 Feb 2003 02:11 pm
