2002 PT Crusier showing 4 codes and wont start
Old 29 May 2010, 02:07 pm
Default 2002 PT Crusier showing 4 codes and wont start
i'm new to the forum and i have some questions. i'm new to the pt cruiser and i've only had mine for 2 months now. I went to start it the other day and it started just fine and then it died a min later. i ran codes on it and it showed me 4 different codes. it showed p1684,p0340,p1685 and p1193 would any of these codes prevent my car from starting? if so what would i do to get it going again?
any help would be greatly appreciated.
Thank you in advance
Old 29 May 2010, 02:39 pm
Default Re: 2002 PT Crusier showing 4 codes and wont start
Welcome. If you check in the performance section there is a sticky showing what the pxxxx stands for. Or use Google.
Old 29 May 2010, 03:49 pm
Dino's Avatar
P0340 CAMSHAFT SENSOR
CIRCUIT
No camshaft position sensor detected (no fuel sync)
How many miles on your PT? Could be the sensor or the timing belt
Old 31 May 2010, 04:19 pm
it has 118,000 miles on it
Old 31 May 2010, 05:39 pm
Dino's Avatar
Does the car just turn over like it's under less stress? I would check your belt they tend to need to be changed at 100k after that your on borrowed time.
Old 31 May 2010, 11:25 pm
The starter cranks really fast but everything on the engine spins alternator,power steering and so on and so forth. It is going to my mechanic tomorrow to have those 2 things checked out. Thank you for the info it has saved me a lot of time.
Thank You,
Matt
Old 01 Jun 2010, 08:41 am
Dino's Avatar
Thank You,
Matt
Your welcome Matt, it's most likely your timing belt, so have them do the water pump at the same time. It's in the same area and you don't want to go through this again so replace it now so you don't have to pay for another major repair.
Work owned 2002 PT Cruiser radio display not showing LotusLord Sound and Security Forum 14 11 Jul 2015 11:44 pm
Engine overheating, Stuck in "Limp mode" showing codes 0188,1490,&1495 Manny Tech & Performance Forum 4 08 Apr 2009 05:39 am
Wont start now? morrisbeer General PT Cruiser Discussions 2 21 Feb 2009 10:14 pm
2003 pt crusier wont start smith4384 General PT Cruiser Discussions 4 19 Jan 2009 02:27 pm
2002 Crusier Front end shake American flyer Tech & Performance Forum 3 09 Oct 2002 03:26 am
