Severe shaking at idle
Old 01 Jun 2010, 07:08 am
Default Severe shaking at idle
My 2000 2.4 cruiser started shaking while i had the AC on waiting to pickup my son from school. So i shut the AC off and it faded away. Now the problem has progressed over the past week to were the car VIOLENTLY shook while idling in a parking lot after a 10 minute drive. I checked the error codes and it gave me 577082 NO FAULT. So no error codes to work off of. Im guessing its a belt "PRAYING IT IS" Anyone wanna take a shot?
Old 01 Jun 2010, 07:23 am
Default Re: Severe shaking at idle
I would like to add i just heard what the sound was the sound and the shaking coralate 100% The fan seems to be hitting something? Or its off balance and hitting something? But the noise definately emulates from the fan.
Old 01 Jun 2010, 08:36 am
Dino's Avatar
Your fan could be bad and drawing too much voltage causing the car to shutter. The fan hitting something I don't think could shake car. One of the first signs you fan might be on it's way out is a shutter in the engine when the fan engages. The fan sucks in the PT, you can get an aftermarket fan for well under 150 bucks for the non turbo slightly more for the turbo.
Old 01 Jun 2010, 08:52 am
Ok i just got it back from a local shop he was 5 miles from the house. I was right and so were you dino about the fan. He states that it will cost me $352.50 for the fan another $44.17 for shop supplies? And 2.2 hours labor at $199.58 with tax and everything its $632.03!!!! Im freaking out, Does this sound right? Im obv going to shop around and he stated that he couldnt find an aftermarket one and that he had to get the stock one from the dealer. Gimme some advice guys thanks!
Old 01 Jun 2010, 09:23 am
Dino's Avatar
It sounds expensive but the dealer fan isn't cheap, you can find the fan under 100 bucks online on ebay and places like this 01 - 05 Chrysler PT Cruiser Radiator Cooling Fan Assembly 02 03 04
I just googled that fan place so I don't know anything about them.
01-05 Chrysler PT Cruiser Radiator Cooling Fan - Yahoo! Search Results
Old 01 Jun 2010, 09:27 am
Dino's Avatar
If you have advanced auto around you they have them for 169
Engine Cooling Fan Assembly by Dorman - Part 620-022 - Advance Auto Parts
Old 01 Jun 2010, 10:11 am
Nice i can order that fan from the local AA phew! Now i need to figure out how to remove this thing and do it myself. Is that a good idea? I have never done anything like it before.
Old 01 Jun 2010, 12:41 pm
chris15's Avatar
I would advise you to pick up a Haynes manual from AA or AZ while you're up there. It'll give you step-by-step instructions on how to do this, and even if you aren't good with a wrench, you should be able to tackle it.
EDIT: This should work as well, but obviously there are no illustrations:
http://www.ehow.com/how_5602850_repl...t-cruiser.html
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 01 Jun 2010, 06:14 pm
If you'll look about 10 threads up from this one (it's a sticky) you'll see that Crewzin was kind enough to put up a "how-to" on fan removal and installation. It's even his own PT that he used for this sticky!
Thanks Crewzin.
Jerry
Old 01 Jun 2010, 06:49 pm
Invidious,
When you checked the fault codes, how did you do it? What you got (577082 NO FAULT) is not what you should see when properly checking the codes. It will either give you a code (P09917) or say "done" if no codes are detected.
My PT is shaking...need your advice MINIHEMI46 General Turbo Discussions 15 13 May 2011 06:49 pm
Rought Idle and shaking on acceleration dsnowden Tech & Performance Forum 6 08 Sep 2009 09:04 am
Flashing CEL - Car shaking Travis2k7 Tech & Performance Forum 11 17 Aug 2009 05:32 am
Now my PT is shaking! UGH! Gracie512 Tech & Performance Forum 6 14 Aug 2009 11:31 am
first severe scratch...gary how to fix this??? cruisergeo The Detail Shop 12 27 Jan 2004 09:08 pm
