Check engine light is still on!
Old 01 Jun 2010, 04:31 pm
Default Check engine light is still on!
hey everyone, My 05 cruiser has been throwing me a code about not getting a signal from the camshaft sensor so I just replaced it, How long does it take for the check engine light to come off? Is there a way I can clear the codes myself cause the local autozone dont clear the codes anymore here in st.louis. I know how to check for them with the ignition sequence.
Old 01 Jun 2010, 06:18 pm
Default Re: Check engine light is still on!
Remove the negative cable for about 15 minutes, see if that helps, that resets the computer.
Old 01 Jun 2010, 06:44 pm
Cowboy, hopefully you put in a Chrysler/Mopar sensor as the PT doesn't like aftermarket (made in ???) parts.
Check Engine Light vgf11 Tech & Performance Forum 9 20 Jul 2017 02:01 pm
Check Engine Light CHROMEDCRUISER General PT Cruiser Discussions 13 30 Apr 2012 04:49 pm
check engine light azphotog Tech & Performance Forum 3 13 Feb 2010 11:45 pm
Check Engine Light On vicky52 Tech & Performance Forum 11 23 May 2009 01:23 am
pt check engine light johnnyb Tech & Performance Forum 9 22 Jul 2008 01:32 pm
