Autolite Double or Single Platinum Plugs?
Old 08 Jun 2010, 06:52 am
falconut's Avatar
Default Autolite Double or Single Platinum Plugs?
I don't have a turbo model, so I don't have to worry about them melting. Now are the double platinum plugs (APP5263) a better plug than the single platinum plugs? They are only $1 more, so if they are, I'm going to go with them. They note that they're good for 100,000 miles. Any input would be helpful.
Old 08 Jun 2010, 08:39 am
Default Re: Autolite Double or Single Platinum Plugs?
From what I know, they start with the center being platinum (single) then for double, the "arm" gets platinum coating, too.
Most wear occurs on the center post, but doing both can't hurt.
What you will get is plugs that ought to last longer... so go double.
Old 08 Jun 2010, 03:19 pm
Double platinum plugs would be preferred over single platinum plugs in a waste spark distributorless ignition system.
Platinum plugs on a turbo? bobdole369 General PT Cruiser Discussions 12 27 Aug 2010 12:12 pm
Double platinum plugs? Rt66Bob Tech & Performance Forum 2 14 Mar 2009 09:11 am
platinum plugs airevac19 Tech & Performance Forum 5 21 Apr 2004 11:30 am
another question re platinum plugs pingber Tech & Performance Forum 7 31 Aug 2003 12:55 am
Platinum Plugs Not Tex Tech & Performance Forum 10 28 Jun 2002 07:12 pm
