2006 - Turn signal/driving lights
Old 09 Jun 2010, 09:27 pm
Default 2006 - Turn signal/driving lights
Hi All,
Not sure if this is a problem, but, when I turn on the turn signals the driving light on that side turns off. For example, when I turn on the right turn signal the right driving light turns off. Is this normal? If not where would I start looking for an electrical problem.
Thanks, Steve
Tarnishedknight
Old 10 Jun 2010, 06:05 am
Default Re: 2006 - Turn signal/driving lights
TK, welcome to the Forum. IMHO, I think you should start by thinking about replacing your MF switch. That's Multi Function, by the way. The PT has a problem with that dang switch and many have had to change them. That is the stalk that your turn signals use. I do believe that there is a "sticky" posted on how to do that. Good Luck!!!
Old 10 Jun 2010, 06:55 am
Steve,
Welcome to the forum. Hooligan is probably right about the MF switch but let me ask a question or two.
Is this PT a used car and did you recently purchase it? I say that because I'm wondering if the fog/driving lights were put in as an added accessory after the car came from the factory by the previous owner. We do have a lot of switches that go bad but I've never heard of the lights going out with the turn signal. Of course there's lots of things that I haven't heard of. I'm just wondering if they were wired up wrong. It just doesn't sound like a burnt out switch just mis-connected wires.
Old 10 Jun 2010, 08:53 am
Don't pay any attention to the two above posts!
This is completely normal. The way the driving lights are designed, when you use your turn signal, the driving light on that side goes out while the turn signal is on. This is to make it easier to see the turn signal for cars ahead of you.
You'll also notice this feature in Town & Countries and 300's with driving lights.
Yours is functioning as designed.
Crewzin, the driving/running lights are part of the headlights, not the fogs
-Chris
Old 10 Jun 2010, 09:02 am
PiperGeorge's Avatar
A lot of the Chryslers do that nowadays. I think it's to make the turn signal more noticeable during the day by turning off the Daytime Running Lights.
Maybe a Canadian thing??? Do you have Daytime Runing Lights on US cars yet?
Old 10 Jun 2010, 10:03 am
Well, I have a problem with that answer. My fogs/driving lights stay ON when I use the turn signals. I just proved it by going out to the garage and putting all the lights on and using the turn signals. None of the other lights went out.
Maybe a Canadian thing??? Do you have Daytime Running Lights on US cars yet?
Depends on which cars. Lots of them do have the DRL's nowaday.
heifetz17, Some people call them driving lights, others call them fogs. To me the fogs would be yellow, whereas driving lights are white, but to get a point across I call them fog/driving.
Old 10 Jun 2010, 02:44 pm
The fogs are not intended to go out when you have a turn signal on. The daytime running lights (part of the headlights) go out when you have a turn signal on. This is so the light from the DRL doesn't interfere with the visibility of the turn signal.
Yes, US cars can have the DRLs activated by any dealer. I have them on mine. They're just not mandated here like they are in Canada.
-Chris
Old 10 Jun 2010, 02:59 pm
OK, I see it now (said the blind man). The first post is from Canada and he's talking about the DRL and not what I was calling the fog/driving light.
Sorry for the confusion.
Old 10 Jun 2010, 03:40 pm
Thanks All, yes I am from Canada so that must explain the confusion, sorry. I should have mentioned that in my post as there seems to be differences. I will have to pay attention to Chrysler cars as I haven't noticed this before, it seems like an unnecessary complication.
Steve
Tarnishedknight
Old 10 Jun 2010, 04:31 pm
TK, I see that you have filled out your profile, that would have helped originally!!! Thanks.
2006 TURN SIGNAL PROBLEM dj78nc General PT Cruiser Discussions 26 24 May 2015 12:52 pm
2006 Touring Edition - Lower lights never turn off EmeraldICE General PT Cruiser Discussions 7 12 Apr 2008 08:59 pm
Turn Signal jmack General PT Cruiser Discussions 5 12 Apr 2005 11:57 am
blue turn signal bulbs that turn orange when in us Capt Kidd General PT Cruiser Discussions 1 04 Jun 2004 10:10 pm
Turn signal gonzomania Exterior Accessories Forum 12 30 Mar 2004 08:53 am
