Cold Start Roughness???
Old 10 Jun 2010, 10:09 am
Exclamation Cold Start Roughness???
Hi all,
I have a question about my 2007 Pt. Every morning when i go out to start it, it turns over, and then the whole car shakes very roughly, then it fires. After it fires, it sounds like it may bog out for a second, and then it runs fine. Is this normal?
Thanks!
Old 10 Jun 2010, 03:11 pm
Default Re: Cold Start Roughness???
No, of course it's not normal. What about your maintenance? When was the last time the spark plugs and wires were changed?
Old 11 Jun 2010, 12:46 pm
No clue. I bought the car used with 33,900 miles on it. All i know is that it was a prior rental.
Old 11 Jun 2010, 01:19 pm
Buy some good wires (not stock) and plugs (gap at 0.040) and if that doesn't cure shake, it was needed anyway....
Tags
2.4, cold start, issue, problem, rough
Upon Cold Start in Cold Weather, Loud Noise?? paulrosenthal Tech & Performance Forum 33 01 Oct 2014 09:55 am
Cold Start ahaddad Tech & Performance Forum 6 29 May 2012 10:02 pm
Timing Belt Was Just Replaced - Oil Warning Light at Cold Start Up ? PURPLE_GT General Turbo Discussions 10 05 Jan 2012 06:58 pm
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
Cold Start Problem Mean Green General Turbo Discussions 2 17 Jul 2004 12:37 pm
