05 rear hatch opens at start up
Old 12 Jun 2010, 11:44 am
Default 05 rear hatch opens at start up
I need help! Every time I turn the ignition switch on, the rear hatch opens on its own. I must have a short some where but don't know where to begin.
Thanks!!
Old 12 Jun 2010, 02:46 pm
Default Re: 05 rear hatch opens at start up
I did a lot of searching on this and it's a strange one. Don't think it's come up before.
I found a person having the exact same problem with, believe it or not, a Jaguar.
Hers, if she just hit the unlock door button once for only the drivers door, everything worked fine but if she hit the remote twice for all the doors to unlock, then when the ignition was turned on, the rear glass (she doesn't have a hatch) would pop open.
The answer from a tech said: Water penetrates the switch and unlocking then happens in response to anything being switched - start engine, switch some other circuit or just at random. The fault is usually the button for opening the rear glass, in your case the rear hatch,this can be changed easily.
Might not be your answer but it's all I could fine. Maybe one of the Tech's on this forum has another idea.
Old 12 Jun 2010, 07:35 pm
Thanks for the info, at least it's some where to start.
Old 21 Jul 2010, 11:39 am
My '05 just started this same thing and it was right after I washed it and opened the hatch to wipe down the inside of the door frame. Guessing I must have gotten water in the switch in the process.
Glad I could find an idea of what to do here.
Old 21 Jul 2010, 03:29 pm
Glad you did too. Hope it works.
Rear hatch unlocks when I get in and start engine. jim1703 General PT Cruiser Discussions 17 13 Feb 2014 11:58 am
Help..rear hatch satownplayer General PT Cruiser Discussions 3 09 Dec 2007 10:21 am
wtb rear hatch josheypt Classifieds: Want To Buy 0 24 Feb 2006 08:19 pm
"flaming" rear hatch.... BumperBob General PT Cruiser Discussions 1 10 Aug 2005 10:07 pm
rear hatch badge Shini Quiet General PT Cruiser Discussions 11 31 Mar 2005 12:41 pm
