Fitch Fuel Catalyst Snake oil or what???
Old 12 Jun 2010, 07:41 pm
Dino's Avatar
Default Fitch Fuel Catalyst Snake oil or what???
Features
* The Fitch Fuel Catalyst is a permanent bolt-on fuel enhancer
* Improve fuel economy by up to 1 - 2.5 mpg
* Enhances fuel quality by boosting the octane in gasoline
* Allows the use of lower octane fuel
* Increases the cetane and lubricity in diesel fuel
* Better fuel quality delivers added horsepower and torque
* High-quality fuel helps reduce emissions
* Reduces number of annual oil changes
* Keeps injectors, jets and spark plugs cleaner for reduced maintenance
* Completely maintenance free—install it and forget it
* Easily installs in your fuel line like a fuel filter
* Your Fitch Fuel Catalyst is backed by a 250,000 mile warranty
Description
Boost power, reduce emissions and save at the pump while you’re at it. The Fitch Fuel Catalyst enhances gasoline by boosting octane and bolsters diesel by improving cetane and lubricity. Designed in union with the Department of Defense, Fitch boosts all fuel types—diesel, gas, even JP fuels.
Fitch Fuel Catalyst pre-treats fuel before combustion. By running through Fitch’s proprietary metal alloy, normal fuels transform into superior-quality fuels. And, quality fuel means more power, increased MPGs and lower emissions. Plus, it allows premium-fuel engines to run lower-grade gas with no performance loss.
Not to worry, the Fitch Fuel Catalyst simply bolts right in under the hood. Each system comes with vehicle-specific quick-release fittings, so it’s easy to patch right in-line with your vehicle’s fuel system. What’s more, your Fitch Fuel Catalyst system is backed by a 250,000 mile warranty.
Fitch Fuel Catalyst, Your Trusted Fitch Fuel Catalyst Source
Old 12 Jun 2010, 07:55 pm
Default Re: Fitch Fuel Catalyst Snake oil or what???
Read on:
Fuel saving gadgets - a professional engineer's view
does the fitch fuel catalyst work ?
Yahoo! Canada Answers - Does the Fitch Fuel Catalyst work?
Old 12 Jun 2010, 08:16 pm
Dino's Avatar
Thanks Crewzin, just what I thought.
2002 PT (in tank) Fuel Pump/ Fuel Sender cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 06:08 pm
Premium Fuel wengerda Tech & Performance Forum 29 17 Aug 2005 09:02 am
Fuel spots under fuel door patbluecruiser The Detail Shop 2 15 Apr 2005 07:01 pm
Fuel RM General PT Cruiser Discussions 8 18 Feb 2004 10:18 pm
