2006 n/a died at redlight
Old 14 Jun 2010, 08:55 am
ChefTank's Avatar
Default 2006 n/a died at redlight
its my sisters, belts are fine, battery is fine, alternator is fine. drove normal until it stopped then it will not start. timing belt intact. pump primes. fuel pressure is good. cant get the key dance to work like my 05 gt..... any guesses? it turns over but will not crank.
Josh
This is my turbo History:
Stock turbo (1 year)
Big Wheel Stocker (3 Months)
50trim (2 Weeks)
Stage 3 (3 months)
Big Wheel Stage 3 (6 months) my Fav
Holset HX35 (6 months) 700whp turbo
Stock turbo its a daily driver now
I've done this once or twice before...
Old 14 Jun 2010, 02:31 pm
Default Re: 2006 n/a died at redlight
Is there an engine light on saying there's some sort of fault? If so, take your time and do the key dance routine again. All the cruisers have it. If your sure all the belts are OK, including the timing belt, my guess would be one of the main sensors like the Cam or Crank sensor. If either one of those go bad, then there's no signal to the computer and the engine won't start. It will crank but that's all.
Old 15 Jun 2010, 10:00 am
If you really can't get the key dance to work, it might be the engine computer died....
How many miles? I think the computer is covered under an emissions warranty - good for 50,000 miles????
Old 15 Jun 2010, 02:55 pm
ChefTank's Avatar
sorry forgot to get back w/ a update... the crew was down so i posted here and forgot.
it was the crankshaft position sensor. installed a new one, got it three blocks from my house and snapped the timing belt (yeah!!!). now it's in the garage and i have it apart waiting on stuff from rockauto to put it back together.
ps- rock auto had a Timing Belt kit including both tensioners, belt, and water pump for $142 shipped yeah for great deals. this is also my sisters pt. My GT has less than 40K and sees maybe 200miles a month
Josh
50trim (2 Weeks)
Stage 3 (3 months)
Old 15 Jun 2010, 03:04 pm
Thanks for getting back to us. Good luck with the timing belt repair.
Old 16 Jun 2010, 05:48 am
Seems that crankshaft position sensor should've thrown a code...
Car just died loudassz Tech & Performance Forum 5 28 Apr 2011 06:24 pm
DASH HAS DIED ! HELP c13ckb Tech & Performance Forum 3 19 Jan 2010 04:36 am
02 pt died and won't crank over ronwins3 Tech & Performance Forum 16 23 Dec 2009 06:25 am
Cooling Fan died JoeHundredAire Tech & Performance Forum 10 11 Apr 2009 02:57 pm
turbo died serape General Turbo Discussions 18 05 Jun 2003 01:47 pm
