Changing transmission fluid and filter?
Like Tree2Likes
Old 19 Jun 2010, 12:37 pm
Default Changing transmission fluid and filter?
Hello,
I have a 2001 pt and, i recently purchased a tranny filter and fluid to change out, The car has 145,000 miles and i dont know if the tranny has been serviced before. One of my buddies seems to think that if i change the filter and fluid that it could potentially cause slippage or damage? any thoughts on this or is there anything to worry about?
Old 19 Jun 2010, 10:32 pm
Dino's Avatar
Default Re: Changing transmission fluid and filter?
Originally Posted by tcnw05 View Post
Hello,
That's one school of thought, but if it was me I would still do it. Just make sure you use the right fluid for Chrysler.
Old 20 Jun 2010, 12:29 am
This can be a very touchy issue if you're not careful. Is the transmission currently having any issues? Slipping, hard shifting, jolting, anything at all? If the answer is yes, do not service it! If the tranny is functioning properly, you'll be fine.
Quite often people will service their trannys when the start having issues hoping for a quick and cheap fix. What happens is when the tranny starts to wear, the clutch packs need the friction provided by the dirty fluid to operate. When you service it and introduce new, clean fluid into it, there's no that friction that there was with the dirty fluid, eventually leading to failure of the tranny.
If you don't have any issues, though, go for it.
-Chris
Old 24 Jun 2010, 03:37 pm
mdfrodolives's Avatar
tcnw05:
I had the dealer change my auto. trans. fluid on my 2003 PT at 50,000 miles (just cause I think thats about enough to ask of auto trans. fluid). I didn't know about this forum at the time--else I would have changed the fluid myself. Also, a "filter" change was required. Anyway, since I had no manual at the time, I let the dealer do the job.
After the change, as soon as I drove the car away from the dealer's lot I noticed that the gear changing times had been altered. The trans. simply didn't change gears at the times I was accustomed to. So when I got home I called the dealer shop--and they said "oops". They had apparently forgotton to "re-learn" the trans.--a necessary item that needs to be done when changing the fluid and filter on PT's. The next day I took it back to their shop. They shot it with their software program (it took about five minutes), and then the trans. shifted just as it had when I first drove it into the dealer.
So, bottom line, if you change your fluid and filter yourself, take it to the dealer afterwards and have them re-learn your tranny.
By the way, I have no idea why Chrysler made this step a part of changing the fluid, but I've seen the results of no "relearning".
As far as NOT changing your fluid until something goes wrong, when I read that here, I was reminded of my brother's theory concerning "preventative maintenance". That is to say that when my brother's car "prevents" him from actually using his car--then and only then does he maintain it.
Go figure....
Tim
Old 24 Jun 2010, 07:29 pm
Dino's Avatar
Originally Posted by mdfrodolives View Post
tcnw05:
Go figure....
Tim
I bought the fluid and filter and paid Pep Boys to change the filter and flush the transmission with the machine to get all the old fluid out. My PT rode and shifted smooth as silk with no retraining needed.
Old 24 Jun 2010, 10:09 pm
01Pittypat's Avatar
Cool Re: Changing transmission fluid and filter?
Hey guys and Gals. I Just changed my filter and fluid today. It was VERY easy to do! She's an 01 with just 51,000 and change on the ticker. Havn't driven the car yet. Had to go to work, But I'll see what happens tomorrow when I take her for a spin. See! I luv this site! I would have never known to even consider the tranny "Re-learning" program.. If I need it! I'll be knocking on my dealer shop door first thing..
Old 28 Jun 2010, 02:56 pm
01Pittypat's Avatar
Pitty Pat update, As I said last week! Changed the fluid and filter myself. Dropped the pan, changed the filter, RTV the pan and back on it went, Filled the tranny using the dipstick tube. Much easier then finding the filler plug WAY DOWN under all that STUFF under the hood. ANyway! NO problems at all after 300 plus miles. SO! don't let the tranny fluid change scare you. Get under there and knock it out..
Old 28 Jun 2010, 04:59 pm
Pittypay, it seems the dealer that changed my fluid and told me the subsequent gear-change problem was because they forgot to "re-learn" the transmission, was mistaken--or else they just forgot to do something else besides re-program the trans.
Good to know.
By the way, I was not aware that there was a fill plug for the auto trans., and assumed that it was always filled from the filler tube....
Tim
Old 28 Jun 2010, 11:01 pm
Dino's Avatar
You can only get half the fluid out with just a drain and refill, the dealer and other places have a machine that will get it all out and replaced with new. What you did was good though but the next time your do you should have it flushed
Old 29 Jun 2010, 08:28 am
VNT's Avatar
VNT VNT is offline
Or they can disconnect one of the lines to the cooler and do a cooler lin flush or in a few months go back under and drop the pan again and inspect and throw in another filter.
Most critical thing when changing the fluid is not to over fill it.
One should also consider a B&M bulkhead style drain plug. When you have the pan off, add the plug. Then when you change oil you could drain and refill the trans and keep the fluid fresh.
mole likes this.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Changing Transmission Fluid garyerrol Tech & Performance Forum 13 27 Jun 2016 05:02 pm
transmission fluid leak joeus Tech & Performance Forum 11 11 Jul 2013 09:18 am
Downshift problem after changing fluid and filter. spartanburgsc General PT Cruiser Discussions 3 24 Jun 2009 07:09 pm
Transmission Fluid scatgo Tech & Performance Forum 4 31 May 2009 09:04 pm
Transmission Fluid DaShado Tech & Performance Forum 1 02 Jul 2007 06:18 pm
