spark plug wire change help
Old 19 Jun 2010, 05:10 pm
demon666's Avatar
Default spark plug wire change help
This is my first time changing the spark plugs and wires on my car 2004 ptc
I have the plugs and wires do i need anything alse before I start taking it apart
I watched a video on you tube they didint say anything about a seal or gasket
do I need to replace it or dose even need one?
Old 19 Jun 2010, 06:47 pm
Default Re: spark plug wire change help
There is a "sticky" in the performance section. You do need a torque wrench tho.
Old 19 Jun 2010, 07:16 pm
Follow all the instructions as hooligan pointed out on this sticky. Disregard anything to do with the EGR, you don't have it.
Use Dielectric grease on the wires and Anti-seize on the plug threads.
Spark Plug Guide
Old 19 Jun 2010, 08:22 pm
demon666's Avatar
do I need seal or gasket ? by the way I have no idea what sticky is ..
Old 19 Jun 2010, 08:36 pm
hi there no you dont need new gasket in less you break it be careful when its off can be reused a few times
Old 19 Jun 2010, 08:41 pm
OK, a "sticky" is the threads on top of each of the sections that are there to help owners out with all sorts of information. They are called stickys because I stick them to the forum where they can't move. They always stay there unlike regular postings where they drop down the list when a new thread comes along.
There's 4 rubber gaskets on the end of the upper manifold that can be used over and over again as long as you take care of them. They are oblong and orange/red in color. Take them out and inspect them for breaks but you can put them back carefully when finished inspecting them. There might be one more between the upper manifold and the throttle body. It's been awhile and can't remember if there is one there.
Old 19 Jun 2010, 09:08 pm
demon666's Avatar
Thats what I was looking for. Once agin thank you for your help.
spark plug wire change on 06 turbo limited manzanman General Turbo Discussions 6 11 Apr 2010 10:11 am
Suggestion on Spark plug and wire? oLEFTo Tech & Performance Forum 13 08 Jul 2009 11:53 am
air filter,spark plug & wire brands/opinions bob67firebird428 Tech & Performance Forum 21 14 Jun 2008 04:05 pm
my experience with plug/wire change mino General Turbo Discussions 2 31 Oct 2007 03:10 pm
Plug & Wire Change Screw Up???? BB Turbo Performance 12 24 Feb 2007 12:15 am
