Radiator Fan - Error code
Old 23 Jun 2010, 10:04 am
Default Radiator Fan - Error code
I have seen a few posts on this, however I have a question of my own.
We have had some troubles recently with the Radiator fan in our 01 PT.
I replaced it maybe 6-8 months ago because I was told it was bad, and it just stopped working again.
Turned out the plug going to the car (the one the fan plus into) has a recessed connection, and when we plugged it in tighter it is working fine.
(we are going to replace that plug but at least we are working at the moment).
Now I have a new engine code of 1490.
The code lists says this is Low Speed Fan Relay Circuit. Now during the troubleshooting process I did disconnect the low speed relay and plug it back in.
Could this code be from taking the relay out or is it an indication of a bigger problem?
Old 23 Jun 2010, 10:27 am
Default Re: Radiator Fan - Error code
Remove the negative cable from the battery. This will reset the computer, leave it disconnected for at least 5 minutes. Then see if the codes appear again.
Error Code bus b8 or 68, not sure. richardbradley Tech & Performance Forum 2 18 May 2010 07:45 pm
Error Code 320 okla2001pt Tech & Performance Forum 1 17 May 2010 12:42 pm
Error Code bds02pt Tech & Performance Forum 2 29 Jan 2010 03:01 pm
S1 error code??? mtnbktrek Stage Turbo Kits 2 24 Feb 2009 01:42 pm
Error Code saldagus Tech & Performance Forum 2 25 Nov 2008 09:51 pm
