Battery light
Old 24 Jun 2010, 12:44 pm
Default Battery light
Hi All savvy PTer's!
My 2004 Base AUTO N/A PT gave me a code P0622, So I tested the entire charging system and nothing was bad. The alternator/starter/battery were good. So we deemed that the PCM was issue(Had a free pepboys diagnostic). I bought a new pcm and made sure it was programmed correctly for the PT and now im still having the same issue. The car is still giving me the battery light on the dash and the same code. Only runs off the battery, im thinking a bad ground or something, Im really not sure what else to do. If anyone has had this issue please advise because im all out of ideas. Thank you in advance!
Old 24 Jun 2010, 02:55 pm
chigger_ns's Avatar
Default Re: Battery light
Did you actually try a different alternator? I would just for giggles.
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
Old 24 Jun 2010, 04:08 pm
I went a step above and bought a new one anyway. By the way the alternator is a pain to remove/install. Still no joy.
Battery light jackski Tech & Performance Forum 10 03 Jun 2013 07:12 pm
Battery light won't turn off devlin333 Tech & Performance Forum 5 07 Jan 2009 05:10 pm
Battery Light On treed Tech & Performance Forum 8 06 Sep 2008 08:50 pm
Battery light sacha33 Tech & Performance Forum 6 12 Mar 2007 07:44 am
Battery light sacha33 General Turbo Discussions 2 25 Feb 2007 10:46 am
