Please Help P0171 Code Still
Old 25 Jun 2010, 09:32 am
Default Please Help P0171 Code Still
Hey guys,
I have been troubleshooting my 01 Limited Pt Cruiser now for weeks to resolve this code. The car has had a tune up with premium plugs, coil pack was changed, and both oxygen sensors have been changed. The weird part: After each part was changed, I would go for a drive and do fine for a while, then at between 12 and 16 miles that check engine light comes back on and it's the same code. Interestingly, it seems to come back on when I go up a steep hill. It seemed to run fine until that light comes on then it wants to hesitate. Any more thoughts? I've run out of ideas and money!! Could this be a stupid vacuum leak?
Steven
Old 25 Jun 2010, 10:37 am
Default Re: Please Help P0171 Code Still
Vacuum leak or you didn't say anything about plug wires. When was the last time they were changed?
Old 25 Jun 2010, 10:43 am
Plugs and wires have been changed recently. The only thing I could think of would be a vacuum leak or map sensor maybe? Fan is working fine, ac blows cold all the time.
Steven
Work done:
New Starter
New coil pack
New plugs & wires
New O2 sensors (both)
Old 25 Jun 2010, 11:54 am
Were the O2 sensors OEM or aftermarket? PT's do not like aftermarket sensors.
Old 25 Jun 2010, 11:55 am
My hunch - intake gasket.
Usually it is # 4 cylinder and usually the lower gasket and usually gives a P0304.
Does it idle smoothly?
Old 25 Jun 2010, 12:05 pm
I don't get code P0304, just P0171. Both sensors were OEM.
Steven
Old 25 Jun 2010, 12:18 pm
I know, but there are a lot of intake gasket leaks - could be you got a different code - is idle smooth?
Old 25 Jun 2010, 03:26 pm
It idle's smooth after it starts but not at first because it still doesn't want to start right. It does idle smooth running at full speed with a/c on. I checked the map sensor. With the car running, I unplugged it and the car shut off which I'm told that is what it is supposed to do. If it is a vacuum leak, where should I start? In regards to the intake gaskets, is that the intake manifold gaskets? I've had the intake manifold off a couple of times doing the plugs wires and coil pack and like a dummy, didn't even think of those gaskets! Argh! Thanks so much!
Steven
Old 26 Jun 2010, 11:33 am
Well, I've got my fingers crossed! I took your advice and this morning I replaced the upper intake manifold gaskets, a dry rotted hose, and noticed a bolt missing on one module so I replaced that too. Drove it pretty hard up hills and down hills for 18.1 miles and the check engine light did not come back on! Jeez, I hope this did it! I am give out!
Steven
Old 27 Jun 2010, 10:31 am
I went to the mall this morning and the CEL came back on. When I got home and pulled the codes, it's still that pesky P0171 code. After all that I have done, other than the lower intake manifold gaskets, what else should I check?
So frustrated!!
Steven
Tags
p 0171
Code ? 1lowufo Tech & Performance Forum 1 25 May 2010 06:25 pm
Code Help jennylyn General PT Cruiser Discussions 1 21 Sep 2009 01:57 pm
Code P0171 leftoverture Tech & Performance Forum 1 12 Jun 2009 06:17 pm
344 code jkinard73 Southeast PT Forum 2 08 Apr 2009 12:54 pm
P0171 Error code RIvey Tech & Performance Forum 3 02 May 2007 10:24 am
