engine trouble
Old 25 Jun 2010, 05:59 pm
Default engine trouble
Help, I have a 2001 pt the engine is missing and sputtering so i put gas dry and gas treatment in and have ran the motor for about a hour with no change. Pulled the computer codes and got codes 1684 and 1391 so i changed out the cam sensor,reset the computer and restarted ran good for a minute and the same two codes 1684 and 1391 cam back. Thanks for any help
Old 25 Jun 2010, 06:23 pm
Default Re: engine trouble
P1684 does not indicate a problem; it's only a status, which indicates that the PCM memory has been cleared within the last 50 ignition cycles.
Fault Code P1391 Intermittent Loss of CMP or CKP
You replaced the Camshaft Sensor and the problem could be that OR the Crankshaft sensor.
Did you use a Chrysler sensor or from an aftermarket parts store?
Old 25 Jun 2010, 07:32 pm
It's from o'reilly, but also it seems to get worse when the engine is warm and has ran for a while.
pt cruiser 2004 engine trouble yogarx Tech & Performance Forum 7 30 Apr 2009 01:50 pm
03 PT trouble Gina General PT Cruiser Discussions 4 22 Feb 2007 02:06 pm
HELP TROUBLE!!!! PTNeo Tech & Performance Forum 4 16 Jul 2004 01:22 pm
trouble again !! OurPTGT Turbo Performance 2 02 Jul 2003 12:37 pm
trouble !! bobs turbo pt Tech & Performance Forum 5 01 Jul 2003 01:32 pm
