Oil pressure light problem - just replaced cam sensor
Old 02 Jul 2010, 01:29 pm
Exclamation Oil pressure light problem - just replaced cam sensor
Hey Guys,
my girlfriend has a 04 Cruiser and the check engine light came on for P0340 - cam sensor, so i replaced that today and now the oil pressure light comes on when the idle drops below 1,500. i checked all the connectors and everything seems intact. anyone have any advice or have had this problem?
thanks
Car has 81k.
Old 02 Jul 2010, 02:54 pm
Default Re: Oil pressure light problem - just replaced cam sensor
Jeremy welcome to the Forum. Hopefully you use OEM & not aftermarket. Our PT's do NOT like aftermarket. That may be your problem.
Old 02 Jul 2010, 03:04 pm
Lots of problems with the oil pressure sensor from owners. Hopefully just a coincidence that the light came right after the Cam Sensor. If it was an earlier model I might suggest that the wiring from the Cam Sensor might have something to do with the oil pressure sensor (above the oil filter) since they both run around the back of the engine but I'm pretty sure they moved the oil pressure sensor to the other side of the engine (around the starter) in 04.
Old 02 Jul 2010, 07:20 pm
nopeee, i went to Advance auto parts and used BWD one. :/
well i had replaced the oil pressure sensor about a month back because the teflon and worn off and was leaking. and have not any any problems with that light until now. but the oil pressure sensor is above the tranny, not sure if thats near the starter or not.
but the light did not come on until i replaced the part
Old 02 Jul 2010, 08:00 pm
More pieces to the puzzle. You've already replaced the oil sensor before. Quite possibly it's a bad aftermarket part (as Hooligan noted) or it was overtightened when put on.
Should be just a coincidence that it came on the same time you replaced the Cam Sensor.
Old 02 Jul 2010, 10:22 pm
yeah, i thought i overtightened it so i took it off and put it back on but the problem was still there. So i let it cool for awhile and just took it out now and hasent come back on since. Kinda fixed itself i guess, but ill keep a close eye on it over the next few days
Crankshaft Position Sensor Replaced But.. SuperTroy General PT Cruiser Discussions 10 01 Jan 2013 06:20 pm
Camshaft pos.sensor replaced ....and??? mtnbktrek General Turbo Discussions 6 21 Jan 2010 07:56 pm
Replaced Camshaft sensor and car still wont start john1561 Tech & Performance Forum 3 29 Jun 2008 06:49 pm
Replaced Temp Sensor, threw P0118 ptguy Tech & Performance Forum 0 08 Sep 2007 04:20 pm
