Help Please ! Electrical issues.
Old 03 Jul 2010, 09:30 pm
Default Help Please ! Electrical issues.
2004 Base PT Out of nowhere today no ac/heat , no window switches , and air bag light stays on. All worked fine earlier today. I have checked all fuses inside and under air filter box = good. Any advice,other than a trip to the stealership would be very appreciated.
Went outside right after posted to close it for the nite and everythng worked fine ? Closed it up to move it of course the same issue returned.
Has to be somethin simple that im missing. No check engine or key dance codes either.
Thanks ....
Old 03 Jul 2010, 10:26 pm
Default Re: Help Please ! Electrical issues.
Welcome to the forum.
I know you said you checked the fuses but here's other owner's with multiple failures....
Pwr Windows/Blower Fan/Back-up lights/Rear Window Defogger/Air Bag Light
http://answers.edmunds.com/question-...-on-31297.aspx
http://repairpal.com/airbag-light-st...op-working-145
Old 04 Jul 2010, 06:28 pm
Default Re: Help Please ! Electrical issues. FIXED !
Thanks Crewzin,
After i tore it all apart,again, finally found the culprit.
The connector next to the steering tilt lever was not "snapped" all the way.
Old 09 Jul 2010, 01:00 am
I just ran into the exact same problem on my '05 base PT. First none of the windows worked, then the a/c,heat fan stopped working and the airbag light came on. All fuses are good. I'll check the connections to see if that is the problem. It's nice to know there are other forums like this to share info. Thanks guys!
Old 15 Aug 2010, 07:08 pm
Originally Posted by thegooch2 View Post
Thanks Crewzin,
Which connector was that? I have the same problem and I am convinced that is were the problem is since I removed a remote starter from under there that the wires were getting wrapped around the steering column and shorting out the 30 amp fuse under the hood stalling the car.
Old 16 Aug 2010, 06:53 am
I have an 03 turbo GT. My Radio, Compass and Sunroof all would go dead on me from time to time. After I checked all the fuses were good I was stumped! Also, this would mostly happen on cold days and after a while of driving...BAM...the radio would come on, sometimes scaring the shit outta me. Anyway, I was always checking the fuses with the car off, but just last week I played with the fuses...pushing on them...and Bam...everything came on. In short, your fuses may be good but the contact that the fuses have to the fuse box may not be. Hope it helps!
Electrical Gremlins SantaGuy General PT Cruiser Discussions 10 24 Sep 2009 05:01 am
Electrical Issues? SillyEB Tech & Performance Forum 5 02 Jul 2009 10:52 am
speaker issues, wattage of stereo, door speaker replacement issues fabes89 General PT Cruiser Discussions 9 02 Jun 2009 10:59 am
Not sure where to put electrical questions? ravix Tech & Performance Forum 9 28 May 2009 09:25 pm
need electrical help thundercat2 Tech & Performance Forum 0 27 Sep 2008 08:02 am
