Timing mark question on a non turbo.
Old 04 Jul 2010, 07:39 pm
chigger_ns's Avatar
Default Timing mark question on a non turbo.
Just put A timing belt and water pump in my PT.
I tried to align the timing marks as best as possible.
My front cam seems to be half a tooth lower than the rear cam with the crank dead on its mark.
It runs smooth but at idle it seems to stall out or stumble of the blue with out warning. Wasn't a problem before. The car seems to run ok on the road.
So, I know its out of time.
What do I do or how do I do it properly. How do I get my marks to line up and should they be in a straight line across the cams?
P.S. I did change it all with out disconnecting my A.C. lines or my exhaust. YAY!
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
Old 04 Jul 2010, 07:54 pm
chigger_ns's Avatar
Default Re: Timing mark question on a non turbo.
Oops I found it here....
need picture of engine specifically the timing belt
Old 05 Jul 2010, 06:23 am
DreamPT416's Avatar
I have to replace my timing belt as well here is an off the wall question do i have to pull the motor or well i get lucky and skip that pain in the butt?
Old 07 Jul 2010, 03:50 pm
chigger_ns's Avatar
Humm, my Pt was in time...
I guess I must of had water in the fuel?
She purrs great now.
DreamPT416, if you are not mechanically inclined or have tool, I would take it to a shop.
You have to do a lot of shinning and jacking to get at stuff and take mounts off.
Old 07 Jul 2010, 04:48 pm
If you did any searching on the forum you'd see nobody has ever had to pull the engine. The engine mount does have to be loosened or taken off so the engine can move a bit to give access to certain bolts.
Quick Question about Timing Marks Jimrea Tech & Performance Forum 1 03 Jul 2010 04:34 pm
TIMING MARK SCREWUP shammesfah Tech & Performance Forum 0 28 Mar 2010 10:14 am
Another possible timing belt question PTBlue_2002 Tech & Performance Forum 2 16 Jun 2009 06:51 am
Timing Belt Question bmore25 Tech & Performance Forum 2 28 May 2008 11:43 am
Another timing belt question thread :) ??? Ctown General PT Cruiser Discussions 4 24 May 2005 08:50 am
