Timing belt change, then CEL code for oxygen sensor?
Old 04 Jul 2010, 11:04 pm
Default Timing belt change, then CEL code for oxygen sensor?
Had my timing belt and water pump changed. After the change, runs as smooth as before with no idling issues. But within 5 miles of driving after the timing belt service the CEL came on. When I do the key dance it shows P0038: HO2S Heater Circuit High Voltage Bank 1 Sensor 2. This should be the heated O2 sensor, I believe. Anyone had this come on after a timing belt change?
Normally I wouldn't think there's a correlation, but it had never thrown a CEL before, and it came on after 5 miles of driving and has stayed on. Anybody had something like this happen?
I'm inclined to test the 02 sensor or just replace it and see if it clears up. Any advice on using an OEM sensor over aftermarket parts?
Old 05 Jul 2010, 05:15 am
Default Re: Timing belt change, then CEL code for oxygen sensor?
PT's do not like aftermarket sensors.
when to change Timing belt ? Ctown General PT Cruiser Discussions 13 18 Aug 2014 05:40 pm
Timing Belt Change? tgibeau Tech & Performance Forum 10 07 Jun 2010 10:21 pm
Belt change help - Not timing belt skfloyd Tech & Performance Forum 2 23 Apr 2010 11:23 am
Timing belt change turbomangt General Turbo Discussions 31 19 Jan 2009 04:48 pm
Timing Belt change calflan Tech & Performance Forum 1 23 Oct 2007 03:52 pm
