ac problem
Old 05 Jul 2010, 10:05 am
Default ac problem
hello all I'm new here and I'm not the owner of the pt but my mother in law is and since im the most mechanically inclined i get to work on it!! which I've always had a place in my hart for the cruiser.
but any who her ac stopped working at the beginning of the summer after working just fine all last year and what i have found out is that the clutch is just not engaging, it has proper pressure and no leaks that i know of, any suggestions on how to check the compressor without getting a whole new one?
Old 06 Jul 2010, 06:59 am
Default Re: ac problem
Welcome to the forum.
You don't memtion what year the cruiser is but I'm taking it that's it between 2000-2005.
Did you check the A/C fuse in the PDC (Power Distribution Center) that's located in the engine compartment?
The high pressure switch itself located on the compressor has been giving problems for some owners. If that's not working properly, the compressor won't enguage.
Old 06 Jul 2010, 09:53 am
yeah sorry its a 03 checked all the fuses and relays and all are intact and good, i even treed that trick with the paperclip on the sensor on the condenser, ill look into the high pressure switch thank you!
any one else have this problem tommeyb General PT Cruiser Discussions 13 07 Apr 2008 12:21 am
is anyone else having this problem? blustar714 PT Cruiser Convertible Forum 0 05 May 2005 11:32 pm
Problem? deederz Tech & Performance Forum 3 04 May 2005 10:19 am
a/c problem deez92 Tech & Performance Forum 11 25 Jul 2004 04:25 am
RDS problem Brad Vandrasik Sound and Security Forum 3 02 Jan 2004 01:15 pm
