Camshaft Sensor Oil leak
  • 1 Post By Busted_PT
Old 06 Jul 2010, 01:31 pm
Default Camshaft Sensor Oil leak
Happy belated July 4th to all. I have a 2006 PT, non-turbo and an engine code directing me to an error in the camshaft sensor. Yes, I bought the OEM part. I noticed a little oil in the area behind the electronic sensor and the magnetic disc. Is that a normal occurance? Thanks for any input or direction to old threads. This is a great place for sharing data.
Old 06 Jul 2010, 01:56 pm
Dino's Avatar
Default Re: Camshaft Sensor Oil leak
Did you change the sensor and did it work? Sorry not sure about the oil I'm sure someone that does will chime in.
Old 06 Jul 2010, 03:33 pm
I used the non-OEm then read about the non-OEM bugaboo on this forum and ordered an original along with some other items from Chrysler parts on Internet. When I replaced with the non-OEM it still acted as if it had a bad miss at times ( run ruff, hard to restart, then run ok for 10-20 seconds followed by 5-10 seconds of miss like condition ). I use an "Auto Xray" analyser and when I came back after installing the non-OEM, it gave me a Anti-Knock sensor code and a bad Oxygen sensor code along with the original replace Camshaft sensor code. It has about 65,000 miles on it. I am going to replace the Spark plugs ( AC 3570(( gapped to .040)), find a new set of better plug wires, both O2 sensors and the Knock sensor ( since it was cheap ) and install the new Can shaft sensor).
Old 08 Jul 2010, 03:52 pm
NGK IRIDIUM PLUGS.........
Old 08 Jul 2010, 09:13 pm
I have replaced twice (first lasted 1-2 months, next one no problems so far) but do notice some oil around it. Not sure if it supposed to have some residual oil but my experience has been no problem. Hopefully someone can shed more light on this. 130K and still going.
Old 09 Sep 2013, 07:08 pm
A bit of oil is ok, according to a friend who is a mechanic. He supervised my DIY repair.
Old 09 Sep 2013, 07:29 pm
Just so you are aware. This particular thread was last active July 2010.
Good to see some new blood on here. Welcome to the circus.
randyincctx likes this.
Old 09 Sep 2013, 10:00 pm
randyincctx's Avatar
Talking Re: Camshaft Sensor Oil leak
Originally Posted by Busa_Powered View Post
Holy thread revival batman!
Hi welcome to the forum tazzy
How are you?
Where have you been?
What drew you to the pt cruiser?
Are you getting the 'thumbs up' from other drivers?
Are you in any local clubs?
Have you made any modifications?
Post some pics of your pt cruiser
I couldn't help myself!....
Aka:~KILLER~
Old 09 Sep 2013, 10:02 pm
Somebody needs to beat you!
camshaft position sensor (CMP) hobbyman Tech & Performance Forum 62 01 Aug 2015 12:43 pm
Camshaft sensor (again!) ABrown Tech & Performance Forum 21 29 Mar 2012 03:31 pm
Camshaft Position Sensor ejschultz Tech & Performance Forum 6 22 Sep 2010 09:58 pm
Camshaft position sensor oil leak 2004PTCruiser Tech & Performance Forum 11 09 Jan 2009 04:00 pm
Camshaft Sensor ABrown General PT Cruiser Discussions 2 18 Jun 2008 07:36 am
