Technical electrical question/cooling fan
Old 10 Jul 2010, 10:58 pm
Default Technical electrical question/cooling fan
2 SPEED COOLING FAN EMERGENCY FIX.
INSTEAD OF PUTING A TOGGO SWITCH OR WIRING IT DIRECT, WHAT WOULD BE THE CONSEQUENCES OF RUNNING BOTH WIRES TO THE WORKING SIDE OF FAN. IT WOULD COME ON WHEN THE AIR WAS TURNED ON AND WHEN THE CAR TEMP GOT TO HOT. BOTH ON AT THE SAME TIME SHOULD CAUSE NO PROBLEMS (DOES ANYONE FIND FAULT WITH LINE OF THINKING?)
THE THE FAN NOT WORKING IS THE AC SIDE.
2004 PT CRUSIER
1ST ONE-
THANKS
Old 11 Jul 2010, 06:38 am
Default Re: Technical electrical question/cooling fan
I'd like to help but I don't get what your thinking? You seem to think you can have the low speed part of the fan running the same time as the high speed?
If that's right, I don't think you can do that. You can either have high or low speed, not both.
P.S. Please don't use all capital lettering when on the forum. It's like shouting.
AC not cooling question rkagan Tech & Performance Forum 12 17 May 2010 10:14 pm
03 gt electrical question jacarc1 General Turbo Discussions 3 27 Mar 2010 06:19 pm
Cooling fan question?????? careyk General PT Cruiser Discussions 4 19 Mar 2010 10:21 am
electrical system question Thrusst Turbo Performance 1 09 Aug 2007 06:52 am
Technical Drawings - Please Help nuffgroove Tech & Performance Forum 3 12 Jan 2002 10:52 pm
