A/C Problem
Old 11 Jul 2010, 11:41 am
Exclamation A/C Problem
Got a quick question with a 2002 Pt 2.4 auto A/C compressor fit on a 2007 2.4 auto?
JEdberg
Old 11 Jul 2010, 11:50 am
Default Re: A/C Problem
I just went to ROCKAUTO.com (where a lot of us get our parts) and plugged in a 2001 and a 2007 PT Cruiser Compressor. Both had the same parts available so I'm pretty sure your answer is YES.
Old 11 Jul 2010, 12:28 pm
Just found out it is not going to work because of the different part numbers mine is a 15c and the one I have is not a 15c. watch out guys before you go and get a used a/c compressor you will turn out like I did going on rock auto and buying one now.
Thanks
JEdberg
Old 11 Jul 2010, 12:41 pm
You both are partially right.
On automatic transmissions, all a/c compressors are the same, and a 2007 will fit fine on a 2001.
Manual transmissions are a different story. In 2007 there were two different compressors, neither of which will work on a 2001.
-Chris
Old 11 Jul 2010, 01:43 pm
JEdberg, It's always "buyer beware" as far as compatability and mainly condition are concerned when we choose to buy used parts. The onus is completely on the buyer to make sure the part is correct and functioning. I will always go to new or rebuilt when it comes to things like a/c compressors, alternators, etc.
Jerry
Old 12 Jul 2010, 01:25 am
Exclamation Re: A/C Problem
Ok So I got to get the old A/C compressor back on to the ol lady can drive it. I go to put the belt back on and it's kicking my a$$ why? I loosed the a/c compressor to see if it would give a little more but I can't get it back on is there a trick or what? because I cant get it on. anyone have a belt digraph?
Thanks Jedberg
Old 12 Jul 2010, 04:42 am
Old 12 Jul 2010, 04:32 pm
Sorry, I wasn't seeing how to post my own issue. I have a 06 Touring and today I started it up, AC was on and about 5 minutes later I smelled something sweet and heard a hiss. Now It blows fine, but the ais cold at all. I do not want to take it somewhere and them just come out and say all needs to be replaced. How can I tell if it is a hose or something worse?
Old 12 Jul 2010, 07:30 pm
Look for STEAM once you notice it HOT. If you notice it steaming, it may be as simple as tightening a hose clamp to replacing a hose.
Old 13 Jul 2010, 10:53 am
Check the nuts also they might have rattled loose also anywhere were you see pag oil theres a leak in the system.
Jedberg
A/C Problem blue03ptgt Tech & Performance Forum 7 09 Jul 2009 07:35 pm
any one else have this problem tommeyb General PT Cruiser Discussions 13 07 Apr 2008 12:21 am
Cat problem?? ggd PT Cruiser Convertible Forum 0 30 May 2005 09:53 pm
is anyone else having this problem? blustar714 PT Cruiser Convertible Forum 0 05 May 2005 11:32 pm
Problem with the PT KingKole02 General PT Cruiser Discussions 11 01 Apr 2004 12:04 pm
