oil in spark plug hole
Old 16 Jul 2010, 12:54 pm
Default oil in spark plug hole
I have a 2004 GT with 121,000 miles, and when I changed the spark plugs I found the no 1 plug hole full of oil, completely covering the top of the plug. No. 2 and 3 were dry, and No. 4 had a small amount of oil. Could this be from a bad valve cover gasket?
Old 16 Jul 2010, 01:10 pm
ROCKETMAN8060's Avatar
Default Re: oil in spark plug hole
Yes!!! I have a 04 turbo and by mistake I over boost the car and that is exactly what happend to me!!! I found oil in all the sparkplugs holes! I change the valve cover and problem solve!!!
ROCKETMAN8060
Old 16 Jul 2010, 01:56 pm
Thanks for your quick response. Is it much of a job to replace? I have extensive experience working on cars, but not much on the PT. It does't look to be very difficult. Thanks for you info.
Old 16 Jul 2010, 02:08 pm
No is not, just get the intake off and you be ok! Make sure to replace the intake gasket when your on it!!!! I have some pictures in my profile when I did mine maybey that will help! Good luck my friend!!!
ROCKETMAN8060
Old 29 Jul 2010, 11:50 am
falconut's Avatar
It sounds like it's not actually the valve cover gasket, but the tube seal gasket. The little round 'o' ring that goes in the valve cover where the spark plug hole is. Make sure to replace them while you're doing the valve cover gasket.
Oil coming out of spark plug hole 2004PTCruiser Tech & Performance Forum 10 31 Jan 2012 11:28 am
Oil in the spark plug 02PurplePT Tech & Performance Forum 4 10 Jul 2010 05:05 pm
STRIPPED SPARK PLUG HOLE chuck2112 Tech & Performance Forum 5 01 Mar 2010 09:52 pm
Spark pulgs and spark plug wires? balvarez814 Tech & Performance Forum 1 13 Aug 2008 08:16 pm
oe spark plug gap? thundercat2 Tech & Performance Forum 3 20 Jun 2008 10:22 am
