Code P300 and P302 engine light on
Old 20 Jul 2010, 07:55 pm
Default Code P300 and P302 engine light on
Wuz up everybody,
Well, I've had my engine light on everysince July4th. It went off for about a week or so and came back on today. I went out to SummitRacing and bought MSD 8.5mm plug wires and Champion 7570 spark plugs. I gapped them at .040
The codes are saying multiple misfires and #2 cylinder misfire. What do I do next? A friend of mine told me its my #2 injector? Can anyone help me out on this one?
Thanks y'all
Old 20 Jul 2010, 08:04 pm
Default Re: Code P300 and P302 engine light on
Welcome to the forum.
Why did your friend say it's the injector? It could be but just wondering how he came by that conclusion. You could have a small crack or leak around the number two cylinder which would cause a vacuum leak. That would give you the same code.
A vacuum leak you can find yourself by spraying WD40 around the intake. The bad injector would have to be diagnosed using a scanner.
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 20 Jul 2010, 08:51 pm
Nationwide auto care also said it was a bad injector, but I was skeptical and wanted a second opinion because I had no engine light on before they did a tune-up on the car. I only have 41K on it. I took the plugs out they installed and the # 2 plug (i believe?) was very black and dirty. The others looked decent compared to that one. I know its not the plugs or wires now. I'm trying to do a process of elimination.
Old 20 Jul 2010, 09:05 pm
Old 21 Jul 2010, 06:56 am
can't hurt to throw a bottle of Lucas injector cleaner in the tank.
Did you try the WD-40 along intake manifold seams as Crewzin suggested? If that smooted out idle, then you have a bad intake gasket.
Double-check that ignition wires are fully seated at both coil & plug end - I found them hard to get fully on...
Check Engine light code help sohc1996 Tech & Performance Forum 8 30 Sep 2012 07:36 pm
Engine Light on P0139 code shutterbug Tech & Performance Forum 6 25 Sep 2011 05:49 pm
Check engine light on - can't get code Pinkbadge Tech & Performance Forum 5 10 Apr 2011 07:01 pm
P0304 code Engine Light On wedge22 Tech & Performance Forum 1 23 Feb 2010 07:02 am
code help -- p1684, p300, p700 dcrider81 Tech & Performance Forum 4 08 Aug 2009 10:26 pm
