PCV location
Old 22 Jul 2010, 08:49 am
Question PCV location
Hi everyone,
Where is the PCV valve on a 2006, Touring ed, type "B" engine? How often does it get replaced?
Thanks
Old 22 Jul 2010, 10:26 am
Default Re: PCV location
On an N/A its at the air cleaner end of the cam cover, next to the E of the word valve. The hose coming out of it goes to the intake manifold.
On the turbo motors its at the other end of the cam cover near the oil filler cap. Naturally, its hose also goes to the intake manifold.
If I remember correctly, there have two differant types used. One is threaded (screws in and out) and the other is a "push-in and then turn" type.
If I were you and you can't visually tell which type you have, I would get it from the dealer. The parts jockeys at the parts stores may not have a clue.
Jerry
Old 22 Jul 2010, 10:32 am
The PCV valve should be checked and or replaced every 30,000 miles according to the owners manual.
The recommened replacement interval is 60,000 miles or 48 months. If most of your driving is stop and go, I would do it sooner.
Jerry
Old 22 Jul 2010, 10:34 am
Your crewzin, but it looks like he's asking about the PCV valve.
Jerry
Old 22 Jul 2010, 10:36 am
it was edited while your typed.
Old 22 Jul 2010, 10:41 am
"What hoppened"? I swear there was one more post in here second ago.
Jerry
Old 22 Jul 2010, 10:44 am
And then I edited to add the word "more". Playing post tag are we. Tag you're it.
Jerry
Old 22 Jul 2010, 10:56 am
I only edited mine with the information about the EGR since I found out the original posted was only talking about the PCV Valve.
Old 22 Jul 2010, 01:12 pm
Thank you very much. I'm at 56,000 miles and never have replaced it. Going to the dealer and picking one up.
IOD Fuse Location D29TEXAS Tech & Performance Forum 2 07 Feb 2010 09:59 am
Hello and Please help with Fuse location DelValPC Tech & Performance Forum 2 01 Jul 2008 02:28 pm
Tee Location Mean Green Turbo Performance 6 07 Jan 2004 01:41 am
Oil Filter Location PT-ERA Tech & Performance Forum 4 23 Oct 2003 01:56 pm
Location for Jack renichms General PT Cruiser Discussions 2 03 May 2002 01:01 pm
