I guess I need to change my brake pads/disc's.
The right rear is really making a noise. 15,500 miles, I need to get a set of brakes that will last longer than 15,000 miles. any ideas? [8] |
Personally, I put Wagner Thermo Quiets on my wife's just to kill the brake dust. They ran about $60 front axle. But there's many more opinions out here.
This would be a good time to replace not just your pads but your discs also. Everyone has their own opinion as to which brand/type is the best. Check out the links/information below for various items available:
Rotors - DBA http://www.dba.com.au/ Cryogenic http://www.cryogenicsofindiana.com/prod01.htm Power Slots http://www.ptuning.com/html/discount...ubid=ptptenthu EBC http://www.brakesrus.com/ Brembo: http://www.nopionline.com/ Pads - Greenstuff http://www.tirerack.com/brakes/brake...uff+brake+pads Raybestos ceramic Pads part #PGD841QS NAPA ceramic pads part# CMX7716. top-shelf NAPA metallic pad is AE7716M Wagner MX-841 is the top-shelf Wagner pad
![]() 2002 Inferno Red PT Limited Photos and more at: http://www.randgraphics.org/PT_Cruiser/demos/index.htm Mercedes Wiki |
How is it you seemingly need to replace pads at 15k? I have 42k and have mucho pad left. Ironically, I want my brakes to wear out so I can replace them with painted rotors & calipers!
Maybe you have a stuck caliper - which would be a warranty item. Doubtful if they will just give you pads under warranty, and would you really want them anyway? If the pads simply just disappeared that quickly, DO NOT let the dealer replace them with another crummy set. Go aftermarket with an independent mechanic. |
Reports on pad life varies from owner to owner. Generally, most have had to replace their front pads by 20k. I would go Raybestos Ceramic Pads, part #PGD841QS, for the front (no/low dust too) and Stillen/Metal Matrix semi-metallic pads, http://www.ptcruisermart.com/, for the rear. Not cheap ($75 for the fronts and $55 for the rears), but performs a lot better than the OEM pads. Some local brake shops carry ARI semi-metallic pads (front and rear) and owners have reported excellent wear characteristics and low dust. My only concern with Wagner Thermo Quiet MX-841 (fronts) is that it is the OEM pad supplier (supposely the same MX-841 pads are OEM installed, but the composition may be different), but many are satisfied with replacing with those pads. EBC (fronts only) has had mixed reviews, some report excessive wear and dust while others say they are great. Moss Motors sells the Mintex HP pads (front and rear), you can do an internet search for owner reviews on those pads.
2002 Almond Pearl Limited Edition 27K It\'s nice to be important, but it\'s more important to be nice. http://sci-fi.ptenthusiasts.net/
My brake light was coming on when I turned a corner caused by low brake fluid. Since it's a closed system I figured I better have the brakes checked. Sure enough, pad thickness was down to 3/32" so I had them replaced and the rotors resurfaced. 33,000 miles on brake pads isn't great but not too bad. Of course brake life, like gas useage, may vary depending on your driving style.
Puck |
you might want to try
performancefriction.com. I had pads (z carbon metallic)on my 79 bimmer. They lasted over 100K. Too bad they don't have them anymore for my application (too old)I would buy them anytime again. |
| Brakes, stalling, gas mileage, maintenance | emr131 | General Turbo Discussions | 13 | 12 May 2005 01:08 pm |
| New Brakes... | matt87951 | Tech & Performance Forum | 26 | 27 Apr 2005 02:38 pm |
| Brakes Squeak | Konkeler | Tech & Performance Forum | 5 | 01 Jun 2004 12:40 am |
| Brakes - Turbo vs GT | quicksilverdon | General Turbo Discussions | 11 | 16 Mar 2004 10:40 am |
| Brakes | Artemis | Tech & Performance Forum | 6 | 14 Jan 2003 11:04 am |
