Replaced Cam Sensor and not corrected
Old 26 Jul 2010, 06:22 pm
Default Replaced Cam Sensor and not corrected
Hi all,
I had my engine light come on and the car started bucking if I tried to accelerate . I had no problem driving home and tried it later with no acceleration problems. I came here and learned how to check the codes.
Had a p0340 code so I ran to the local Advanced Auto Parts and bought a new sensor.
After installing the sensor I still have the code and engine light. Any suggestions?
Do I have to reset the computer?
Any help is greatly appreciated.
Don
Old 26 Jul 2010, 07:39 pm
Default Re: Replaced Cam Sensor and not corrected
Use an OEM sensor. Aftermarket sensors are notorious for not working with the car's computer properly.
-Chris
Old 26 Jul 2010, 07:51 pm
Go with genuine Chrysler/MOPAR parts.
Old 26 Jul 2010, 08:07 pm
Thank You. I'll stp and get one in the morning and put it in at lunch. Wonder if I can return the one from the parts store. Never know.
Thanks for the support on this forum too.
I have not had a single problem with my 2006 PT Touring Edition until this.
I do love my PT.
Don
Old 27 Jul 2010, 05:19 am
It wouldn't hurt to remove the negative cable for about 10 minutes to reset the computer!!!
Old 27 Jul 2010, 06:49 am
Thanks. I woke up this morning to the malfunction light out an no fault code so I'm hoping it doesn't come back. Thanks again.
Don
Old 27 Jul 2010, 08:22 pm
Computer reset and running flawlessly. Thanks everyone
Old 28 Jul 2010, 09:19 am
Thanks for getting back - many times we are left guessing if problem was cured.
Tags
cam sensor, engine light, p0340
Crankshaft Position Sensor Replaced But.. SuperTroy General PT Cruiser Discussions 10 01 Jan 2013 06:20 pm
Oil pressure light problem - just replaced cam sensor jeremyrocksursox Tech & Performance Forum 5 02 Jul 2010 10:22 pm
Camshaft pos.sensor replaced ....and??? mtnbktrek General Turbo Discussions 6 21 Jan 2010 07:56 pm
Replaced Camshaft sensor and car still wont start john1561 Tech & Performance Forum 3 29 Jun 2008 06:49 pm
