'02 Cruiser Overheating- Please Help
Old 27 Jul 2010, 10:36 am
Default '02 Cruiser Overheating- Please Help
Hi All, first time poster here.
I have a '02 PT Cruiser Non Turbo Base model that is overheating (actually temp gauge is drifting up about an 1/8th inch from midline but I know the problem is only going to get worse) Here are the facts:
1. Car has about 100,000 miles
2. I replaced radiator, water pump and thermostat at about 90,000 mark
3. My Fan is not coming on when car starts or when it warms up after idling.
4. I suspect my fan used to work at driving speeds because AC would be warm and then cool when the car was moving.
I "THINK" the problem is my fan went from working some of the time to dying all together because of the fact that radiator, thermostat, and water pump are relatively new.
Anyone else have a similar problem? I am having my fan replaced and will probably flush and refill coolant. Again, any help would be appreciated.
Thanks
Old 27 Jul 2010, 11:12 am
Default Re: '02 Cruiser Overheating- Please Help
Welcome, it sounds like you have identified the problem your self. Good Luck!!
Old 27 Jul 2010, 04:41 pm
You think a new fan assembly and coolant flush will do it or could it be something else? Thanks!
Old 27 Jul 2010, 05:38 pm
grapeknutz's Avatar
These cars have a notoriety for the fan motors being weak. The fan motor has a hi and a low speed, the low speed is foe the A/C and the hi speed is for the radiator air draw. Chances are the hi side is out and not running.
Replace the motor and that should cure that.
Old 27 Jul 2010, 05:53 pm
Fan motor!!!
Old 31 Jul 2010, 07:53 pm
i am having the same problems, except i have a new fan. what could it be?
Old 31 Jul 2010, 08:00 pm
Have you also replaced the radiator, water pump and thermostat? If so, there's the high and low speed relays, the fan fuse and the engine coolant temperature sensor.
You could have air trapped in the coolant system or a leaking head gasket.
Old 31 Jul 2010, 08:44 pm
i have replaced the fan, radiator, thermostat, coolant temperature sensor, and water pump. i don't think that the head gasket is leaking. there aren't any signs of it. i have not checked the relays or bled the coolant system, but the fuse is fine.
2003 pt cruiser overheating madcop811 Southeast PT Forum 33 06 Feb 2012 10:55 am
'01 Cruiser overheating issue Mavvy1954 Tech & Performance Forum 9 06 Jul 2010 04:01 pm
01 pt cruiser strange overheating stixboy General PT Cruiser Discussions 11 15 Jun 2010 12:07 pm
PT cruiser Overheating - fan isn't running Torashi Tech & Performance Forum 4 13 Jul 2009 01:37 am
Another OverHeating Cruiser....... FloridaCrusier29 General PT Cruiser Discussions 8 26 Jul 2007 09:25 pm
