LIghting Problem
Old 27 Jul 2010, 04:11 pm
Default LIghting Problem
My 2006 Cruiser's running, tail and dash lights all went out at the same time. Headlights and dome lights are fine. Have checked the MFS but cannot determine if that is the problem. Any suggestions? or does anyone have the wire diagram for the multifunction switch?
Old 27 Jul 2010, 04:28 pm
Default Re: LIghting Problem
Here ya go:
Old 28 Jul 2010, 12:28 pm
Do you know how to rewire so the taillights are switched on automatically, bypassing the MFS? I have four wires coming into the MFS (Black, Red, Red/white, and White/red), and a 5 or 6 wire ribbon out to the wiper control.
Old 28 Jul 2010, 04:53 pm
Wouldn't have the foggiest idea how to re-wire to do that and wouldn't want to try. I know a lot of owners have problems with the MFS but usually it's caused by the fog lights. You said nothing about fog lights so I'm guessing you don't have them. With a 2006 model, I'd be looking for another electrical problem other than the switch, but I could be wrong.
Old 04 Aug 2010, 03:08 pm
Any suggestions on how to diagnose? I don't see any common fuses. I'd like to rewire the wires on the MFS to check each component individually.
Old 05 Aug 2010, 10:54 am
Did you check all your fuses. Including one in the engine bay? If so and they are all still off. then replace the MFS - its about 80 dollars. There is a way to check it but your going to need a tool to do it. Pull the cover off the steering colum follow the harness into where it plugs into the MFS. the toll we used was a cheep one of those 12 volt testers that just lights up. Probelm I can not remember waht color one we were connected to but if you got the right wire then when you turn the MFS on and you see not light then you know its the MFS. if you get power then you start tracing from there.
hope it helps
Lighting problem please help Torres2410 Exterior Accessories Forum 2 13 Mar 2010 08:57 pm
Undercar Lighting SmittysPT Exterior Accessories Forum 4 09 Jul 2007 06:40 pm
Under-Car Lighting PTKollar Exterior & Interior Styling 4 21 Jul 2005 09:54 am
Lighting problem midnight03 Exterior & Interior Styling 18 04 May 2004 09:12 pm
Under-Lighting tsatrasen Exterior Accessories Forum 0 17 Jun 2002 07:21 pm
