Custom Wheels
2004 LE Turbo missfire/ pinging
Old 28 Jul 2010, 12:31 am
Default 2004 LE Turbo missfire/ pinging
I have a 2004 PT Le turbo with automatic. I have noticed a miss at idle and a bog/ ping while accelerating. The engine light comes on and goes off intermitantly.
Tonight it was on and then flashed for about 10 seconds and then stopped flashing, just stayed on.
From what I've read here, it sound like it's time for plugs and wires. What type wires and plugs? And what is the correct gap. BTW, car has 28k miles on it. Can I do this myself? Or what should it cost to have it done? Any other suggestions? Modern cars scare me when I look under the hood.
Old 28 Jul 2010, 05:23 am
Default Re: 2004 LE Turbo missfire/ pinging
Welcome to the Forum. If you go to the performance section and click on the plug sticky, it will tell you everything you need to know about the plugs & wires.
2008 Silver Steel Metallic, Touring, NA, Sirius; Chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty Cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals, '05 Rear Step Pad, Stainless Door Sills, Llumar tint, "A" Piller chrome
Old 28 Jul 2010, 07:54 am
Welcome.
You have the aluminum intake manifold, which is the easiest for plugs/wires.
The stock Champions aren't bad, you can get Good wires from RaceAndStreet.
Gap at 0.040, and use anti-seize on the plug threads (dab) and dielectric grease on the plug boots.
Old 29 Jul 2010, 11:17 am
Okay, I replaced the wires with some Magnicore blues. The only plugs available at the local Auto Zoo were autolight AP5263. I watched them gap them at .040. Now the car runs worse. If I stomp it at a light or at low speed I get sputter sputter sputter ZOOOOM. I re- checked all my conncetions and they're all good. I am also noticing what sounds like valve clatter. WTF? NO codes, either. Should I just take it to the stealership? Do the wires/ plugs void my waranty? HELP! this is my only car.
Old 29 Jul 2010, 11:23 am
When I said no codes I Meant NO Engine Light.
Terrible missfire? allhale09 Tech & Performance Forum 8 12 Apr 2009 09:24 pm
Crazy missfire ! ptTurbo528 Tech & Performance Forum 5 28 Mar 2006 11:43 pm
Missfire & backfires Turbo Red General Turbo Discussions 6 18 Oct 2004 07:58 pm
Pinging Engine"It's Not a Turbo" wheels1950 General PT Cruiser Discussions 8 16 Feb 2004 01:50 am
"Pinging" kidturbofan Turbo Performance 21 14 Oct 2003 02:16 pm
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
  Cookers | Market and finance | Anime | Cheap Home Insurance | Debt Help
