fan low speed
Old 28 Jul 2010, 02:57 pm
Gia Gia is offline
Default fan low speed
I have 2003 PT Cruiser. When cold (let's say in the morning) AC is not efficient. The air is not that cold. I have checked the fan. One morning Low Speed was on, another morning it was not. Is it motor or relay?
Old 28 Jul 2010, 03:14 pm
Default Re: fan low speed
Very seldom to we ever hear of the relay going bad. It's usually always the fan. start the car in the morning when the engine is cold without the A/C on. Open the hood so you can hear/see the fan. It shouldn't be running. Now turn on the A/C and the fan should come on with the compressor.
That doesn't test both speeds of the fan but if it doesn't come on when the A/C is turned on, at least you know one speed isn't working and the fan motor/ fan assembly needs to be replaced to repaired
Old 28 Jul 2010, 03:22 pm
Gia Gia is offline
Thank you so much for your prompt reply and advice. I did exactly what you have just suggested. One morning (when the engine was cold) the fan was running, next morning (again the engine was cold) it was not.
Old 28 Jul 2010, 03:27 pm
You didn't say if the A/C was on when you did your test but the fan should ALWAYS come ON when the compressor is running.
Old 28 Jul 2010, 03:30 pm
Gia Gia is offline
A/C was on in both occasions...
Old 28 Jul 2010, 03:37 pm
Try something else. You say it's not very efficient. Get up to speed, over 35mph, that's when the fan shuts off by the computer because enough air is coming through the front end to cool everything off. Does the A/C seem cold? Does it seem less cold when you slow down or come to a stop?
If so, your fan is probably your problem.
Old 28 Jul 2010, 03:38 pm
Gia Gia is offline
...more, in both occasions I could hear the compressor running
Old 28 Jul 2010, 03:41 pm
Gia Gia is offline
YES, at a speed above around 40 MPH A/C works fine. When slowing down, no cold air.
Old 28 Jul 2010, 03:50 pm
Gia Gia is offline
Thank you. I will have the fan replaced.
Top Speed ? TripleJackInGA General Turbo Discussions 17 23 Jun 2010 10:24 am
Top Speed. Alex_Clarke General PT Cruiser Discussions 11 06 Jul 2009 10:15 pm
More Speed rreyan General Turbo Discussions 30 31 May 2009 03:37 pm
Is the 4 Speed A/S realy a six speed? Ian-PT-GT General Turbo Discussions 11 16 Apr 2004 10:19 pm
GT 5-speed better than SRT 5 -speed? boosta General Turbo Discussions 15 01 Dec 2003 10:42 pm
