windows get stuck when it is hot
Old 29 Jul 2010, 03:08 pm
Gia Gia is offline
Default windows get stuck when it is hot
When it is too hot outside (let's say 38C, 100F) rear windows get stuck, they do not move up. Once the car is moved to the shade and it cools a bit, the windows work fine again. Any suggestions as to the possible reason?
Old 29 Jul 2010, 03:25 pm
Default Re: windows get stuck when it is hot
My hunch is the rubber seals. Lower window all the way down, spray the sides and the bottom "lip" with silicone spray. THe silicone stinks for a while, but quickly goes away and dries clear.
It also can't hurt....
Old 29 Jul 2010, 06:50 pm
I assume you've tried both the front and rear window switches? My PT had issues when it was hot with the front windows (my wife swore it was totally random when she drove it; I only had issues in the heat). It turned out that the connectors on the switches were going bad. I replaced the front 4 switches for about $100 and haven't had issues yet.
Old 30 Jul 2010, 01:27 am
Gia Gia is offline
Thank you all.
Old 30 Jul 2010, 12:05 pm
Although motor failures generally are fairly uncommon, it's possible that your motors are getting weak, and when they become hot like that they don't work until they cool down.
-Chris
hatch stuck yourlefthand General PT Cruiser Discussions 3 13 May 2010 09:33 am
stuck in denver careyk General PT Cruiser Discussions 8 21 Dec 2009 09:02 pm
Stuck in the mud Andre General PT Cruiser Discussions 9 29 Oct 2009 10:11 pm
What's the worst MOD you got stuck with? stirfry General PT Cruiser Discussions 10 13 May 2004 09:20 pm
stuck throttle Punch General Turbo Discussions 9 02 Feb 2004 06:56 pm
