Code 1391 Sometimes I can't see the crank or cam sensor signal
Old 29 Jul 2010, 04:30 pm
Default Code 1391 Sometimes I can't see the crank or cam sensor signal
Thought it was the cam sensor and replaced but still have the same problem. About 20 minutes into driving the car dies and doesn't start right back up. Can anyone tell me what to check next?
Old 29 Jul 2010, 04:42 pm
Default Re: Code 1391 Sometimes I can't see the crank or cam sensor signal
Did you replace with OEM or aftermarket. Our PT's do not care for aftermarket sensors.
Old 29 Jul 2010, 04:54 pm
...and it could be the Crankshaft sensor instead of the Camshaft sensor. Also the wiring harness for the Camshaft sensor has been known to have rubbed against parts of the engine causing a short in the wiring.
Old 29 Jul 2010, 04:59 pm
Wink Re: Code 1391 Sometimes I can't see the crank or cam sensor signal
yes it is oem. Prior to getting the part, I read on hear that you should get OEM so that is what I did. $74. A little more than I expected but what can a person do. Where is the crank sensor located. I will check the wires really good to but when I did look I didn't see anything unusual. Thanks.
Old 29 Jul 2010, 05:12 pm
You didn't mention what year PT you have. If it's a 01-03 the Crank sensor is right above the oil filter. If it's later, Chrysler moved the sensor around to the other side of the engine around the starter.
Check the wiring harness to the Cam sensor first. Its been know to rub against parts of the engine and wear into the wires.
Mine came off the back side of the engine and hung low enough to rub on the spinning half shaft on the passenger side. Wore right through the harness and burnt the wires. Not fun at 1130pm going 80mph on a highway in South Carolina.
Me the next day being towed to a Chrysler Dealer (Phone Camera pic)
Old 29 Jul 2010, 05:25 pm
2001 pt 5 speed. I will check it. Thanks for the fast response! I will let you know!
Old 29 Jul 2010, 05:57 pm
Old 29 Jul 2010, 08:01 pm
Talking Re: Code 1391 Sometimes I can't see the crank or cam sensor signal
Seems the problem is on the crank sensor...one wire is bare and very fragile. Thanks for the help!
Old 29 Jul 2010, 08:06 pm
That would do it. Good luck.
upstream o2 sensor and code p0132 wingman1861 Tech & Performance Forum 5 27 Oct 2009 06:04 pm
01 PT with cam/crank code problems dcrider81 Tech & Performance Forum 21 22 Jul 2009 09:58 am
Cam Sensor code changed sensor still dead RottenKid Tech & Performance Forum 8 18 Nov 2008 08:17 am
MAP sensor & code 108 twoyacks General Turbo Discussions 0 13 Sep 2008 05:51 pm
