'06 AC compressor issue
Old 01 Aug 2010, 05:53 pm
Default '06 AC compressor issue
I have an '06 limited and it seems my AC compressor isn't coming on. It started off with the high pressure hose having a leak so I changed it out, refilled the coolant, and now it seems the compressor isn't coming on at all. I tried the LPS trick with a paperclip and got nothing. I located the HPS and because of where it is I can't tell if I'm making a good connection with it to tell if that switch is out either. The fan is definitely working, but I changed the 50amp fuse just to be sure. Still nothing. Everything was working fine until the high pressure hose and coolant leaked out in the beginning. Is there another fuse somewhere I should be looking for? Is there something better I can do to tell if the HPS is bad? Any suggestions would be helpful.
Thanks-
Old 01 Aug 2010, 09:55 pm
Default Re: '06 AC compressor issue
How much freon leaked out? The freon contains PAG oil, and if it all leaked out and the compressor ran dry, it likely siezed.
-Chris
AC Compressor Question dckoone General PT Cruiser Discussions 5 24 Aug 2010 09:44 pm
AC Compressor rfsexton Tech & Performance Forum 2 05 Dec 2009 08:04 pm
AC Compressor for 01 mrcarlosmorales General PT Cruiser Discussions 2 15 May 2009 01:24 pm
AC compressor rickmancc Classifieds: Want To Buy 0 10 Jun 2008 10:55 am
ac compressor gail Tech & Performance Forum 2 07 Aug 2003 04:47 am
