Problem after timing belt replacement.
Old 02 Aug 2010, 09:33 am
Default Problem after timing belt replacement.
After replacing the timing belt on my 2004 PT non-turbo the car starts and idles perfect but but when it is driving it boggs down (stutters, misfires) when the automatic transmission shifts. Once it is in gear it runs fine again. The check engine light is on but I have not had the codes read yet. I am wondering if I damaged a sensor or wire during the timing belt installation. Any ideas are greatly appreciated.
Old 02 Aug 2010, 11:16 am
Dino's Avatar
Default Re: Problem after timing belt replacement.
Check the codes with the key dance and than check the code, it sounds like the cam shaft position sensor, just changed mine.
Old 06 Aug 2010, 02:54 pm
Here is the info:
The code was P0016 which is the camshaft position sensor. I reset the code and drove the car to verify that it was the problem. Car continued to stumble at gear shift and the light came back on and was the same P0016.
I replaced the camshaft position sensor as well as the stock wires and plugs. I am still getting the same code and stumbling on gear shifts otherwise runs smoothly.
Old 06 Aug 2010, 02:57 pm
Where did you get the sensor? There have been numerous reports that aftermarket sensors cause the problem - pay a few bucks more and get it from dealer - also check wiring....
Old 06 Aug 2010, 04:03 pm
I bought the camshaft sensor from the dealer. I checked the wiring and everything looked good.
I have read P0016 is also the code for camshaft and crankshaft sensor out of sync. I wonder if it is possible that I have the timing off by one tooth on one of the camsprockets. I think I am going to open it back up and check the timing. Any other suggestions?
Old 06 Aug 2010, 04:11 pm
Usually, won't idle nice one tooth off.... There is the crank sensor....
Old 09 Aug 2010, 01:23 pm
My guess was correct and the timing was off by one tooth on the intake camsprocket. I thought I had been very carefully and checked and double checked but it was my error. I replaced the camshaft sensor for no reason
($60).
Old 09 Aug 2010, 07:17 pm
Dino's Avatar
($60).
Your dealer stealer charged you 60 bucks, I just paid 30 and change at my dealer. Well anyway the sensors to go so you ahead of the curve now, good luck.
Timing Belt Replacement MarkB Tech & Performance Forum 108 08 Aug 2017 12:59 am
Timing belt replacement snakepitt1 Tech & Performance Forum 10 18 Dec 2016 12:17 am
Timing belt replacement??? HELP!!! CRFDAD Tech & Performance Forum 4 07 Jan 2009 08:14 am
Timing Belt Replacement? Kawika Tech & Performance Forum 14 15 Dec 2007 11:56 pm
Timing belt replacement? mojogator Tech & Performance Forum 3 12 Nov 2003 03:30 pm
