2006 PT Cruiser Cruise Control
Old 03 Aug 2010, 01:53 pm
Question 2006 PT Cruiser Cruise Control
My cruise control has stopped working. It shows it activated when I press the on button and then push the lever down to set it, but no cruise. I went to the engine compartment and checked the fuses and really do not know what fuse is for the cruise control. Still checked them all and they checked out ok. I removed the vacuum hose at the servo and definitely heard the air release in the vacuum line. Replaced the cable on servo thinking it was stretched but still no cruise. Is there a relay or something that I am over looking? I am also told there are no inside fuses on the left side on the 2006 or above PT Cruisers. I would appreciate any suggestions on this problem.
Thanks.
Old 03 Aug 2010, 08:47 pm
xwing777's Avatar
Default Re: 2006 PT Cruiser Cruise Control
My 04 had a bobble a while back. Same thing, showed it was on in dash but didnt work. Pulled the battery cable off for a few minutes and re-connected it.
Took it for a spin and it worked fine. That was months ago and still works no problems. I think with everything going on in the computers on cars now days they are just like humans.....gets to confusing sometimes and they need a break
Old 04 Aug 2010, 08:35 am
Hey thanks! I am going to try it this morning and drive it for a few miles to set the computer back to normal and then try using the cruise. I sure hope this works.
Old 04 Aug 2010, 07:05 pm
xwing777's Avatar
After you remove the battery cable, hit the brakes a few times to bleed off any power then let set a few minutes, then re-connect the cable.
PTC OEM Cruise Control Kit PCFIXER Classifieds: For Sale/Trade 4 18 Jul 2009 01:45 pm
Help please, cruise control adamw General PT Cruiser Discussions 7 30 May 2009 12:33 am
cruise control CloughBrengle Tech & Performance Forum 6 04 Jan 2009 04:38 pm
cruise control cook General PT Cruiser Discussions 7 30 Dec 2003 09:36 am
Ad on Cruise Control Mike Gallen Tech & Performance Forum 1 05 Feb 2003 06:10 pm
