P0551 Error code
Old 04 Aug 2010, 10:50 am
Default P0551 Error code
Again!!
I asked about this a while ago and after the dealer having my Cruiser and finding nothing wrong, the engine management light went out.
The car was perfect until I went on the motorway for the first time since the last problem, which was this week, on the way home on came the light again! Same problem. Next day...off goes the light!
Cant understand it, maybe my cruiser just doesnt like motorways...thats the only time it happens.
(Not keen on them myself, maybe it comes out in sympathy )
Seriously though...could it be anything to with the air intake? Maybe somethings blocked and it doesnt get enough air when doing above 60mph? Im just guessing, but no-one seems to have a clue why it does this.
Thanks guys!
Old 04 Aug 2010, 12:24 pm
Default Re: P0551 Error code
If you google P0551, you'll find it's the power steering pressure switch.
First step is to be sure ps fluid is full (takes ATF + 4)
Old 04 Aug 2010, 01:08 pm
Thanks for the reply, but we already checked all that and no-one can find anything wrong!
Old 04 Aug 2010, 01:17 pm
Okay....then
1) Disconnect battery to reset engine light & see if it comes back
2) if it does - buy a new PS Pressure switch and replace
3) Still? Drain all PS fluid and replace with new
4) Still? - consider a new PS pump
Old 04 Aug 2010, 03:17 pm
Will try that..thanks
Old 04 Aug 2010, 03:26 pm
P0551 is failure of the power steering pressure switch. The only possible causes are a bad switch, a bad PCM, or a short somewhere in the switch's wiring. The pump and fluid have nothing to do with this code.
Replace your pressure switch.
-Chris
the dreaded p0551 code - stumper djfox1 Turbo Performance 17 16 Apr 2016 08:14 pm
Error Code bus b8 or 68, not sure. richardbradley Tech & Performance Forum 2 18 May 2010 07:45 pm
Error code?? whiteknight Tech & Performance Forum 3 15 Mar 2008 10:29 pm
Remedy for a P0551 Code silentsam74 Tech & Performance Forum 1 06 Sep 2007 07:34 am
Code P0551 - How Serious? BB General PT Cruiser Discussions 8 17 Aug 2005 11:12 pm
