Error Code P0344
Old 04 Aug 2010, 03:36 pm
Default Error Code P0344
I have a 2003 GT.
I had my timing belt done last week. While doing the tear down they found that the tensioner pulley was busted so they also replaced that. A couple days ago this code came up so we replaced the camshaft sensor. Yesterday while driving on the expressway this code came up again and anytime I got near 60mph the car seemed to lose power and pull to the right. I went 50mph the rest of the trip and didn't experience any other symptoms. Any ideas?
Old 04 Aug 2010, 04:55 pm
Default Re: Error Code P0344
Assuming you used OEM sensor?
Old 04 Aug 2010, 04:57 pm
Yes I did.
Old 04 Aug 2010, 05:16 pm
Originally Posted by CherylK View Post
Yes I did.
That's good. Now you need to check the wiring harness from the sensor all the way round back of the engine and make sure there's no spot that the harness has rubbed against something that would wear through the harness and burn the wires. It happen to mine and several other owners on this forum.
Error Code bds02pt Tech & Performance Forum 2 29 Jan 2010 03:01 pm
error code... superpug666 Tech & Performance Forum 16 13 Oct 2009 07:33 pm
ERROR CODE PLEASE HELP Andrew514 General Turbo Discussions 2 27 Jun 2009 10:52 pm
Error Code saldagus Tech & Performance Forum 2 25 Nov 2008 09:51 pm
Error code??? russ00001 Tech & Performance Forum 0 29 May 2007 04:24 pm
