Oil change trouble/major leak
Old 05 Aug 2010, 06:19 pm
aix aix is offline
Default Oil change trouble/major leak
Hello. Tried to do an oil change on an auto 2004 pt cruiser na. drained the old oil/took the old filter off. Put the new filter on, put oil in. Started it up, then noticed a huge puddle under the car. Engine started to seize and I shut it down. What could be the issue? Filter/plug is on tight. Oil cap is on tight. not sure what else to check. any help would be great. going to the store to get more oil now.
Old 05 Aug 2010, 06:31 pm
Default Re: Oil change trouble/major leak
I once did the same thing (when I was young). When I took the old filter off, it left the rubber gasket/ring stuck to the hot metal of the filter holder. When I put the new filter on, that made two rubber rings and they don't screw on tight or it leaves a space somewhere and the oil comes flowing out.
Check that out to see if there's two gaskets.
Old 05 Aug 2010, 08:04 pm
aix aix is offline
thanks for the advice. talk about a double screw up. first o'rileys gave me the wrong oil filter, gave me one for a turbo, which is why i always pull my own parts. second there was still an old gasket on there we didnt see due to it being a little dark. thanks for the advice. all is well.
Old 05 Aug 2010, 08:21 pm
OK, glad you found the trouble.
By the way, you can use the Turbo filter on a non-turbo. It's the same size diameter just a little bit bigger in depth. Takes a little bit more oil to fill it up. Here's a thread that someone started on it.
Turbo oil filter on non turbo???
Old 05 Aug 2010, 08:23 pm
aix aix is offline
ah so it would appear thats why it threaded on there. just the second gasket was the issue. good to know.
Old 05 Aug 2010, 09:14 pm
Bet you'll never change oil again without looking up to see if everything is clear. I don't.
How Do I Fix THIS? Major Scratches... NewPTCruiserInPA The Detail Shop 12 02 Oct 2009 03:15 pm
My First Major Repair Johns Steel Blue Tech & Performance Forum 5 20 Feb 2009 09:13 pm
MAJOR CHRYSLER SERIOUS PT RECALL careyk General PT Cruiser Discussions 1 01 Apr 2008 10:02 pm
Uh oooh! Major Recall azptcruiser General PT Cruiser Discussions 21 20 Sep 2004 01:44 pm
