SHAKING AT START UP
Old 08 Aug 2010, 07:44 am
Cool SHAKING AT START UP
MY 2001 PT. ENG. SHAKES AT START UP? I HAVE NEW PLUGS&WIRES
TIMING BELT. ITS ONLY AT START UP AFTER 2MIN. IT RUNS GREAT.
ANY HELP ? THANKS PRIEST.
Old 08 Aug 2010, 08:57 am
Default Re: SHAKING AT START UP
Welcome to the forum.
First. Please don't use all capital letters. On the Internet, it's like shouting all the time.
Now on to your problem. When was the timing belt and plugs/wires job done? Did the shaking start right after that? Did yo or anyone else check out the motor mounts? I believe one mount has to be disconnected to do the timing belt and it's a possibility that it was left undone when the belt was replaced. Because of the torque on the engine at start-up, you'll notice the shaking more at that time if the motor mount is no connected or broken.
Old 08 Aug 2010, 10:24 am
no the mounts are new.it only shakes on 1st start up the rest of the day its
fine. yes it did it before timing work.and it only last 1 to 2 min.i have no codes
may be cam sen.? thanks.priest
Old 08 Aug 2010, 10:42 am
I would think if it was the Camshaft sensor it would do it all the time.
Did some searching and the main consensus is the motor mounts but you said they were new. Then I saw where the EGR valve or 02 sensor could be going out as they both act on the engine when it's cold and change things when it warms up. Only problem is, both the EGR valve and 02 sensors would send a code to the computer causing the fault lite to come on if they were malfunctioning.
That's all I have. Hopefully someone else will have other ideas for you.
Old 08 Aug 2010, 12:03 pm
Dino's Avatar
Maybe an intake manifold gasket leak???
Severe shaking at idle invidious Tech & Performance Forum 13 05 Nov 2013 04:30 pm
My PT is shaking...need your advice MINIHEMI46 General Turbo Discussions 15 13 May 2011 06:49 pm
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
Flashing CEL - Car shaking Travis2k7 Tech & Performance Forum 11 17 Aug 2009 05:32 am
Now my PT is shaking! UGH! Gracie512 Tech & Performance Forum 6 14 Aug 2009 11:31 am
