03 strting issue
Old 11 Aug 2010, 10:56 am
Unhappy 03 strting issue
Not that I really want to double post but I thought I would create a new thread encase the other is getting lost amongst the other replies,
I hope someone can help...
My wife has an 03 Pt Cruiser that doesn't start anymore. It is a bit of a lengthy story so bare with me since I have tried a lot of trouble shooting to try to remedy this.
So when I turn the key it clicks (solenoid popping out) but does not turn over. I then tried boosting it which did not work thinking it was just a dead battery or something. Thinking it was the starter at this point (hope this is a logical step) I got one from a scrap yard. After struggling for a while (im a newbe at fixing cars) I got the starter in. It worked it started.... But wait unlucky me a week later the same symptoms happened won't start. I took the original starter and hooked it up to the battery and and it does spin (doesn't mean that it has enough torque to start the engine i know).
I have tried getting a code from the ignition no code present however the check engine light flashes 10 times before going solid. ( don't know if that means anything) Borrowed a friends code reader and it says no codes found (not too surprising) Got some contact cleaner and sprayed the crap out of just about everything including the starter relay. With a Volt meter I get 12 volts on the starter post and get 12 volts on the spade connection when the key is turned.
HELP PLEASE
Old 11 Aug 2010, 11:11 am
Default Re: 03 strting issue
Examine the cables going to the starter and battery. I'd say buy some new ones from nearly any auto place - leave the old ones there, add the new ones in parallel.
Could issue now be battery?
Old 11 Aug 2010, 02:11 pm
Dino's Avatar
You should at least have your battery and alternator tested at a place that will do it for nothing like autozone/advanced/pep boys and just eliminate the easy stuff.
Old 11 Aug 2010, 02:38 pm
Correct me if I am wrong but I was using a portable 700Amp booster and with the battery disconnected it should at least turn over and it doesn't so that would mean it probably isn't the battery. Also I didn't think that the Alternator had too much to do with actually starting the car or at least letting it turn over.
Old 11 Aug 2010, 06:19 pm
Dino's Avatar
Have you tried the booster again since you got it started the first time, I was thinking that maybe you are dealing with two issues, You may have fixed the starter but now have either a battery that doesn't keep a charge or an alternator that isn't charging. Good luck it sounds like you have a weird one on your hands.
Old 11 Aug 2010, 07:13 pm
Yeah I have tried boosting it again since the second time it died.
Old 12 Aug 2010, 04:53 pm
Here is some more info I am racking my brains but good on this one and I would appreciate some suggestions.
There are no codes (did the turn key 3 times and comes up with done) however if I turn it even just once after a moment it dings at me and the check engine light will flash 10 times before going solid.
I am going to try and bypass the wiring by running another wire in parellel I forgot to bring some wire home from work and i don't have any thing around the house that i could use.
Old 12 Aug 2010, 07:00 pm
90% figured out so far. It is a wiring issue like quicksilverdon had originally stated. However what wire is still my issue since I don't know exactly how a starter works. I got a wire and hooked it up to the positive battery terminal with a jumper cable and I poked it down and touched the solenoid and it popped out. Then I touched the terminal (not the one that the battery is hooked up to) and the starter would spin. I got my wife to turn the key (which engaged the solenoid) as I made contact with the terminal and it started. EXTREMELY frustrating part is now the dumb car starts on its own now.
Old 12 Aug 2010, 09:12 pm
Dino's Avatar
Dam bro I feel for you, I'm not sure what that flashing check engine light means but your not the first one that has brought it up.
Old 19 Aug 2010, 04:34 pm
Well that issue is resolved. It was the positive power cable going to the starter. It read 12 volts at the starter which really through me off. However I disconnected it and there was a 60 Ohm resistance across that cable. Replaced it with an overkill #2 wire and seems to be starting fine now.
Tags
starter
HID issue CYCLONE_06 Tech & Performance Forum 0 16 Apr 2009 08:00 pm
02 PT issue jparksp Tech & Performance Forum 4 18 Feb 2009 12:11 am
A/C issue. hermtm2 General PT Cruiser Discussions 9 26 Jul 2008 08:40 pm
the oil issue zoned Tech & Performance Forum 3 17 Nov 2004 09:47 am
