how do i fix code P 1495?
Old 11 Aug 2010, 11:35 am
Default how do i fix code P 1495?
new to the forum & want my idiot light to go away, what do i do?
thanks all
Kevin
Old 11 Aug 2010, 01:44 pm
Default Re: how do i fix code P 1495?
Welcome to the Forum.
Which idiot light do you mean? Some times if you remove the negative cable for about 10 minutes, it will reset the computer.
Old 11 Aug 2010, 01:51 pm
it is the check engine light, i got the code p 1495 (leak detection pump solenoid circuit) & would like to fix my car
Old 11 Aug 2010, 05:37 pm
Kevin,
How much experience do you have?
SYMPTOM
P1495-LEAK DETECTION PUMP SOLENOID CIRCUIT
WHEN MONITORED
Immediately after a cold start, with battery/ambient temperature between 4.4 C (40 F) . F and 32 C (90 F) . Coolant temperature within -12 C (10 F) of battery/ambient
SET CONDITION
The state of the solenoid circuit does not match the PCM's desired state.
POSSIBLE CAUSES
Wiring Harness Intermittent
Leak Detection Pump
Fused Ignition Switch Output
LDP Solenoid Control Circuit Shorted To Ground
LDP Solenoid Control Circuit Open
PCM
Leak Detection Pump System
The evaporative emission system is designed to prevent the escape of fuel vapors from the fuel system. Leaks in the system, even small ones, can allow fuel vapors to escape into the atmosphere. Government regulations require on-board testing to make sure that the evaporative (EVAP) system is functioning properly. The leak detection system tests for EVAP system leaks and blockage. It also performs self-diagnostics. During self-diagnostics, the Powertrain Control Module (PCM) first checks the Leak Detection Pump (LDP) for electrical and mechanical faults. If the first checks pass, the PCM then uses the LDP to seal the vent valve and pump air into the system to pressurize it. If a leak is present, the PCM will continue pumping the LDP to replace the air that leaks out. The PCM determines the size of the leak based on how fast/long it must pump the LDP as it tries to maintain pressure in the system.
Old 11 Aug 2010, 06:10 pm
Dino's Avatar
Did you have your gas cap off or is it loose?
Code ? 1lowufo Tech & Performance Forum 1 25 May 2010 06:25 pm
Code Help jennylyn General PT Cruiser Discussions 1 21 Sep 2009 01:57 pm
Engine overheating, Stuck in "Limp mode" showing codes 0188,1490,&1495 Manny Tech & Performance Forum 4 08 Apr 2009 05:39 am
Code Help! 1lowufo Tech & Performance Forum 1 21 Aug 2004 07:03 pm
HU code ? 03LtAldPTGT Sound and Security Forum 3 01 Jun 2004 05:07 pm
