Wierd issue with engine not starting
Old 12 Aug 2010, 12:04 pm
Send a message via Skype™ to wedge22
Default Wierd issue with engine not starting
Got into the car yesterday and turned the key and got a wierd clicking noise, the stereo and dash lights came on but then the dash lights would go off again if the brakes were depressed. I tried the 3 turn trick for the engine code but no code was given. I then decided maybe it was the battery so attempted a jump start, still the same problem. We then had a mechanic come round and check it out, not the starter motor either, but he did a little sequence of depressing the brakes and leaving the key turned to Auxillery. He also had the headlights on and they were very dim, then all of a sudden they went to full brightness and he turned the ignition on a the car started, he tried again several times and it worked. He did not charge us but advised me to look on the web for the cause as he was unsure what it was, especially with no engine codes. I tried to start the car again this morning and it had the same problem, I could not get it to work, hence the post here.
PT Cruiser my first car in nearly 3 years
Old 12 Aug 2010, 12:45 pm
Default Re: Wierd issue with engine not starting
I think you guessed it right the first time, battery. Do you have places you can take it to so they can test it out? Most of our auto stores will check it out for free.
Old 12 Aug 2010, 01:19 pm
Canadian Tire maybe????
Old 12 Aug 2010, 01:20 pm
My wife just called me and said that she got into the car and the needles on the gauges were moving up and down very quickly on their own, the key was not in the ignition??? Would this still be a battery issue?
Old 12 Aug 2010, 01:50 pm
Yep, according to what has been reported, the gauges start acting erratic.
Old 12 Aug 2010, 01:52 pm
Thats good news then, I will buy a new battery and replace it tonight, maybe I dont need to spend lots of money on a mechanic now.
Old 12 Aug 2010, 02:57 pm
Also check the ends of the battery cable to make sure they are on solid. You may have to check the ones to the starter as well.
Engine overheating + P0551 = belt issue? crackdtooth Tech & Performance Forum 0 20 Jul 2010 09:31 pm
PT Starting Issue - Please Help Me Out Here jake326305 General PT Cruiser Discussions 7 24 Feb 2010 10:41 am
Engine light issue Silverlemon General PT Cruiser Discussions 4 10 Feb 2009 06:52 pm
Wierd Horn Problem digitalpinscruiser Tech & Performance Forum 3 07 Jun 2008 06:23 am
The engine temperature Issue. hermtm2 General PT Cruiser Discussions 4 28 Dec 2007 05:17 pm
