oxygen sensor location
Old 13 Aug 2010, 12:23 pm
Default oxygen sensor location
Hello, can anyone tell me where exactly is bank one sensor 2 on a 2006 non- turbo PT? I need to replace it, coded 138. Thankyou.
Old 13 Aug 2010, 01:42 pm
Default Re: oxygen sensor location
There is a little confusion as to which is which because the place I usually get my information from says:
1/2= O2 sensor before the cat.
2/2= O2 sensor after the cat. Actually on the left side of the CAT.
Someone on the forum said it's the other way round. Personally, if you got that code, why not change them both? If one is bad, the other can't be far from going bad also.
Old 13 Aug 2010, 02:31 pm
Our PT's don't like aftermarket sensors, please use OEM's.
Old 13 Aug 2010, 05:40 pm
I have an 06 non turbo. You can get to the first one (before the cat) from the top side. As the pic shows it's in the center close to the firewall. You can use a wrench or check out the 02 wrench from your local auto parts store.
I bought one 02 sensor from O-Reilly's and the other from Auto Zone and haven't had any trouble.
Oxygen Sensor luvmypt Tech & Performance Forum 15 23 Aug 2017 04:32 pm
Location of the crankshaft position sensor on 2005 pt cruiser jimbo1 General PT Cruiser Discussions 14 05 Jun 2012 06:51 pm
location of crankshaft sensor in 2002 dream crusier lilstarfire64 Tech & Performance Forum 1 23 Jul 2010 10:25 am
Timing belt change, then CEL code for oxygen sensor? p_ridge_pt Tech & Performance Forum 1 05 Jul 2010 05:15 am
Oxygen Sensor??HELP?? mjb457 Tech & Performance Forum 0 22 Jul 2007 09:56 am
