spit'n & sputter'n
Old 14 Aug 2010, 01:19 pm
Default spit'n & sputter'n
have an 03' Cruiser... always had kinda a little miss since we bought it last fall, now that summer is hear we're having all kinds of problems... car starts right up with no problems... go to drive it and starts to sputter here and there.. sometimes real bad like its in the intake "popping" .. if the a/c is on... REAL BAD!!!! does this in town the most...stalling out twice so far... will do it on the highway sometimes when going up hill... almost like its straining the motor... then it misses, pops, and sputters.... have to let up on the gas a little and start over....??? after it goes though all of this it idles rough with an occasional miss.... any help would greatly be appreciated!!! thanks in advance ~Ron
Old 14 Aug 2010, 02:02 pm
Default Re: spit'n & sputter'n
Ron, welcome to the Forum. When was the last time you or someone changed the plugs and put something other than stock wires in it?
Old 14 Aug 2010, 08:08 pm
Dino's Avatar
Is the engine light on?
Old 14 Aug 2010, 08:54 pm
light will come on occasionally... sometimes will flash about 5 times then go off... sometimes will just stay on.. does this during the spittin and sputtering episodes...
Old 14 Aug 2010, 08:56 pm
haven't messed with plugs or wires yet, was all new when bought car... first thing on list!!! was seeming like something more along the fuel issue...? did the key dance thing tonight.. flashed P0300 & P0301.. checking on those codes now!!!
P0300 Engine Misfire Detected
P0301 Cylinder 1 Misfire Detected
hoping the new plugs and wires solve the trick... will keep ya updated
Old 14 Aug 2010, 11:22 pm
Dino's Avatar
Don't get the stock wires
Old 16 Aug 2010, 09:12 pm
thanks all for the help!!!! car is running great and not showing any codes!!!! at last
Old 16 Aug 2010, 09:47 pm
I have the same issue with my PT its an '05...its reading p300 and p302. I changed the plugs and wires and the check engine light is still on. I think it may be the fuel injectors? Any suggestions? Coil? I have MSD 8.5mm wires and Champion plugs.
Old 16 Aug 2010, 09:55 pm
Did you take the negative battery cable off for about 10 minutes to clear the original code?
Old 17 Aug 2010, 08:59 pm
disconnected pos. for about 15-20 mins... checked for codes... none.. started and runs great!!!!
