Large gauge green wire from alternator
Old 18 Aug 2010, 08:42 pm
Default Large gauge green wire from alternator
Need help found a large gauge green wire not conected to anything near the starter and pt wont start 70k miles 05 manuel base model. was able to follow the wire to alternator where up front do I connect the other end pictures will be helpful if possible
Life is great when rolling with a beagle dont leave home without one
Old 18 Aug 2010, 09:27 pm
Default Re: Large gauge green wire from alternator
Dad,
On mine, the large green wire goes to the large bolt on the end of the solenoid which is on top of the starter. The green wire should have a round silver connector with a hole in the middle that goes over the bolt. Look on that bolt and you should see that connector where the green wire broke off.
TAKE OFF THE NEGATIVE BATTERY TERMINAL BEFORE CONNECTING THE GREEN WIRE.
Old 18 Aug 2010, 09:41 pm
thanks crewzin is there also the large red postive battery wire attached their
weird it came off
Old 18 Aug 2010, 09:50 pm
YES, a large red wire sort of coming from a different direction than the green wire but going to the same bolt.
DON'T FORGET TO TAKE OFF THE NEGATIVE CABLE FROM THE BATTERY BEFORE YOU DO ANYTHING.
Old 18 Aug 2010, 09:57 pm
thanks a lot i already have the battery out completely
Old 19 Aug 2010, 08:44 pm
It didnt come off do to driving I put a lot of work into getting it to run right so when I was done a buddy decided to be funny "i am going to kill him" and took it out to screw with me. He didnt lable it. I thought It went where crewzin said but in home electricity green is ground white or red hot balck return . sinse the red was there I assumed it was the possative and green ould be ground tthats what I get for thinking though
Old 19 Aug 2010, 09:20 pm
So, did it work ??
Old 19 Aug 2010, 10:31 pm
yes sir thanks again
Old 19 Aug 2010, 10:38 pm
Glad I could help. All I needed was a flashlight.
Engine rebuilt, this one green wire... monkihead Tech & Performance Forum 4 21 Jun 2011 06:14 am
Hit 'n Run Monday... Large Photos Travis2k7 General PT Cruiser Discussions 66 18 Oct 2010 12:30 am
Need a way to remove a large dent HackMATTr The Detail Shop 7 05 Aug 2010 01:02 am
Headlight Wire Gauge arkansascarnut Exterior & Interior Styling 0 15 Oct 2008 10:59 am
Large FMIC unit for the GT Exhaust Depot Vendors & Buyers Forum 3 04 May 2004 11:19 pm
